Clicking noise with ESP32 and Lib Version 2.3.4
Hallo members,
I’m reading in the forum for a long time. And until now I’ve always found help in topics of other members. Thx for the great community and especially for the many people who put a lot effort in this project!
But now I’m struggling in my project. I had my bldc motor setup running at round about february/march of this year when I had to focus on other topics. Know I jumped back to the BLDC motor implementation with the newest Libs (and old code) of Version V2.3.4 and realised a clicking noise when the motor is rotating. It’s there when the motor align procedure is running and when the motor is turning at some angular velocity. The motor is quiet when the speed is (very) low.
To find the root cause I first isolated my setup und reduced it to the minimum. This means exclude the driver board (MKS ESP32 FOC), motor (GB4106) and the Encoder (AS5047P with SPI) from the rest of the project and tested it again with no success.
I then switched back to the Lib Version V2.3.2 and realised that the clicking noise disappeared. The setup is running in voltage torque mode. I use PlatformIO as IDE. The code is 100 % identical.
Does anybody else observed a similar problem when switching to the lates lib version? I suggest it has something to do with “Transition to the arduino-esp32 version v3.x (ESP-IDF v5.x)” that was made in this version. But is only a suggestion. Maybe I have to adjust some parameters I don’t know of when using this Version.
Here are two videos of the noise when using Lib V2.3.4 and 2.3.3 (which was latest “working” lib Version I’ve found):
Here are parts of the platformio.ini file:
V2.3.3 setup:
platform = espressif32
board = esp32dev
lib_deps =
  # works without noise:
  https://github.com/simplefoc/Arduino-FOC#v2.3.3
  https://github.com/simplefoc/Arduino-FOC-drivers#v1.0.7
  SPI
  Wire
V2.3.4 setup:
board = esp32dev
lib_deps =
  # clicking noise with platform = espressif32 and platform_packages = ... :
  https://github.com/simplefoc/Arduino-FOC#v2.3.4
  https://github.com/simplefoc/Arduino-FOC-drivers#v1.0.8
  SPI
  Wire
platform_packages =
  framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git
  framework-arduinoespressif32-libs @ https://github.com/espressif/arduino-esp32/releases/download/3.0.4/esp32-arduino-libs-3.0.4.zip
Please let me know if someone has a suggestion on how to solve the clicking noise issue. Also let me know what kind of other information would be helpful to narrow down the problem.
greetings
bedyn
3
As a new menber I could only post one link.
So here is the other video without the clicking sound.
Perhaps this may help? Please check.
Thanks Valentine for your reply. I’ve already seen this thread but couldn’t find any points to try in my setup. Let me summarise:
  • lib_archive = false build flag → check
  • no print statements in main loop → check
  • test only one motor → check
The supply/motor voltage topic didn’t seem relevant for me, because the noise is only present when I switch to the Lib V2.3.4. But I double checked it and corrected the values a little bit and it reduced the clicking noise a little bit. That means that it appears at a bigger target value.
You also mentioned a counter over-flow issue. I don’t know what to check or where to find more information on this.
Anyway, I striped down my code to a minimum. Maybe someone will find a critical part or give me some hints on what to test next. But I think there must be some lib changes from V2.3.3 to V2.3.4, the ESP32 toolchain or maybe the API…
greetings
bedyn
#include "SimpleFOCDrivers.h"
#include "encoders/calibrated/CalibratedSensor.h"
#include "encoders/as5047/MagneticSensorAS5047.h"
// #include "myUtils.h"
BLDCMotor motor0 = BLDCMotor(7);
BLDCDriver3PWM driver0 = BLDCDriver3PWM(32,33,25,22);
#define sen0_CS 5 // MKS-ESP32 -> SCL_1
#define sen1_CS 13 // MKS-ESP32 -> I_1
#define sen_mosi 23 // MKS-ESP32 -> SDA_1
#define sen_miso 19 // MKS-ESP32 -> SDA_0
#define sen_sclk 18 // MKS-ESP32 -> SCL_0
#define EncoderSPISpeed 5000000 // SPI Speed for encoder
SPIClass * spi_bus_ptr = NULL;
SPISettings mySPISettings(EncoderSPISpeed, AS5047_BITORDER, SPI_MODE1);  // siehe Definition in "simplefoc-driver"; https://community.simplefoc.com/t/challenges-going-faster-than-certain-rpm/1688/19
MagneticSensorAS5047 encoder0(sen0_CS, false, mySPISettings);  // https://github.com/simplefoc/Arduino-FOC-drivers/tree/master/src/encoders/as5047
bool skip_sens_allign = false;
bool skip_curr_allign = false;
bool calibrate_motor = false;
float target_velocity = 0;
float i_alpha;
float i_beta;
const int dt_clock_us = 200;
unsigned long time_now_us = 0;
unsigned long time_now_1_us = 0;
unsigned long t_chk_phase = 0;
unsigned long t1 = 0;
unsigned long dt1 = 0;
DQCurrent_s current;
PhaseCurrent_s  current_phases;
AS5047Diagnostics diagnostics;
bool diagFl1 = false;
bool diagFl2 = false;
bool drv_disable_Fl = false;
bool drv_enable_Fl = false;
bool fl_normal_loop = true;
bool fl_chck_Ph_a = false;
bool fl_chck_Ph_b = false;
bool fl_chck_Ph_c = false;
static long count_move = 0;
bool fl_bg_meas = false;
bool fl_bg_down = false;
bool fl_sens_zero = false;
bool fl_check_encoder0 = false;
const int N_meas = 2500; // Angenommene Anzahl der Messwerte fuer Array
const int mod_meas_val = 50; // jeder x Wert wird nur gemessen
String inputString = "";      // a String to hold incoming data
bool stringComplete = false;  // whether the string is complete
int i;
char send_str[300];
int t_ms_start;
double current_a[N_meas];
double current_b[N_meas];
double current_c[N_meas];
bool flCheckCommand = false;
const unsigned int MAX_INPUT_ = 50;  // how much serial data we expect before a newline
char ser_char_Arr[MAX_INPUT_];
char char_arr_small[15];
char *char_arr_small_ptr = char_arr_small;
// InlineCurrentSense current_sense0 = InlineCurrentSense(0.01f, 50.0f, 39, 36);  // etsten beide Args muessen mit float def. werden, z.B. 0.01f, 50.0f
// include commander interface
// comander functions
void doTarget(char* cmd) {
  command.scalar(&motor0.target, cmd);
void doMotor(char* cmd) {
  command.motor(&motor0, cmd);
void setup(){
  while (!Serial) {;}
  _delay(5000);
  Serial.println("Serial ready!");
  // Debug:
  SimpleFOCDebug::enable();
  // initialize encoder hardware
  spi_bus_ptr = new SPIClass(VSPI);
  spi_bus_ptr->begin(sen_sclk, sen_miso, sen_mosi, sen0_CS);
  encoder0.init(spi_bus_ptr);
  delay(100);
  motor0.linkSensor(&encoder0);
  // ------------------- driver config ----------------------
  driver0.voltage_power_supply = 20;
  driver0.pwm_frequency = 25000;
  driver0.voltage_limit = 20;
  driver0.init();
  // link the driver to the current sense
  // current_sense0.linkDriver(&driver0);
  motor0.linkDriver(&driver0);
  // init motor
  motor0.init();
  motor0.phase_resistance = 16.;
  // current_sense0.init();
  // current_sense0.gain_b *= 1;
  // current_sense0.gain_a *= 1;
  // motor0.linkCurrentSense(&current_sense0);
  motor0.voltage_sensor_align = 8;
  // --------- motor0 Parameters V2 ------------
  motor0.PID_velocity.P = 0.07;
  motor0.PID_velocity.I = 0.05;
  motor0.PID_velocity.D = 0.0;
  motor0.PID_velocity.output_ramp = 0.0;
  motor0.PID_velocity.limit = 2.0;
  motor0.LPF_velocity.Tf = 0.01;
  // angle loop PID
  motor0.P_angle.P = 20.0;
  motor0.P_angle.I = 0.0;
  motor0.P_angle.D = 0.0;
  motor0.P_angle.output_ramp = 0.0;
  motor0.P_angle.limit = 20.0;
  motor0.LPF_angle.Tf = 0.1;
  // current q loop PID
  motor0.PID_current_q.P = 3;
  motor0.PID_current_q.I = 300.0;
  motor0.PID_current_q.D = 0.0;
  motor0.PID_current_q.output_ramp = 0;
  motor0.PID_current_q.limit = 10.0;
  motor0.LPF_current_q.Tf = 0.01;
  // current d loop PID
  motor0.PID_current_d.P = 3;
  motor0.PID_current_d.I = 300.0;
  motor0.PID_current_d.D = 0.0;
  motor0.PID_current_d.output_ramp = 0;
  motor0.PID_current_d.limit = 10.0;
  motor0.LPF_current_d.Tf = 0.01;
  // Limits
  motor0.velocity_limit = 70.0;
  motor0.voltage_limit = 10;
  motor0.current_limit = 3.0;
  motor0.foc_modulation = FOCModulationType::SinePWM;
  motor0.modulation_centered = 1.0;
  motor0.torque_controller = TorqueControlType::voltage;
  // motor0.torque_controller = TorqueControlType::dc_current;
  //motor0.torque_controller = TorqueControlType::foc_current;
  motor0.controller = MotionControlType::torque;
  //motor0.controller = MotionControlType::velocity;
  motor0.motion_downsample = 10.0;
  motor0.useMonitoring(Serial);
  motor0.monitor_downsample = 100; // set downsampling can be even more > 100     // hier Fehler in Beispielcode
  //motor0.monitor_variables = _MON_CURR_Q | _MON_CURR_D; // set monitoring of d and q currents
  motor0.initFOC();
  // set the initial motor target
  motor0.target = 0.0; // Amps - if phase resistance defined
  // command.add('T', doTarget, "target velocity");
  command.add('T', doTarget, "target");
  // add the motor to the commander interface
  // The letter (here 'M') you will provide to the SimpleFOCStudio
  // //motor0.monitor_variables = _MON_TARGET | _MON_VEL | _MON_ANGLE;
  // motor0.monitor_variables = _MON_CURR_Q | _MON_CURR_D; // set monitoring of d and q currents
  motor0.monitor_variables = 0;
void loop(){
  // if((unsigned long)(micros() - time_now_us) > dt_clock_us)
    if (fl_normal_loop) {
      t1 = micros();
      time_now_us = micros();
      motor0.loopFOC();
      count_move++;
      if (count_move % 20 ==0) {
        //motor0.move(target_velocity);  // muss regelmaessig durchlaufen werden!
        motor0.move();  // muss regelmaessig durchlaufen werden!
        count_move = 0;
      // current_phases = current_sense0.getPhaseCurrents();
      // current_phases.c = -(current_phases.a + current_phases.b);
      // i_alpha = current_phases.a;
      // i_beta = _1_SQRT3 * current_phases.a + _2_SQRT3 * current_phases.b;
      dt1 = micros()-t1;
      // Serial.println(dt1);
    if (fl_check_encoder0)
      if (count_move % 50 ==0)
        encoder0.update();
        Serial.print(encoder0.getAngle());
        Serial.print("\t");
        Serial.println(encoder0.getVelocity());
    }  // End fl_check_encoder0
platformio.ini File:
[platformio]
default_envs = project
[env]
framework = arduino
monitor_filters = send_on_enter
monitor_eol = LF
# dummy
[env:project]
[env:esp32dev]
build_src_filter =
  +<main_MKS_ESP32_V1.cpp>
#  +<myUtils.cpp>
monitor_speed = 115200
board = esp32dev
lib_deps =
  # works with platform = espressif32:
  # https://github.com/simplefoc/Arduino-FOC#v2.3.3
  # https://github.com/simplefoc/Arduino-FOC-drivers#v1.0.7
  # works with platform = espressif32 and platform_packages = ...:
  SPI
  Wire
platform_packages =
  framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git   # siehe Infos in https://community.simplefoc.com/t/having-hard-time-using-v2-3-4-in-platformio/5246/9
  framework-arduinoespressif32-libs @ https://github.com/espressif/arduino-esp32/releases/download/3.0.4/esp32-arduino-libs-3.0.4.zip   # siehe Infos in https://community.simplefoc.com/t/having-hard-time-using-v2-3-4-in-platformio/5246/9
lib_archive = false  # um simplefoc korrekt zu kompilieren
build_flags =
  -Wl,-u_printf_float  # freischalten float in sprintf Fcn; https://www.e-tinkers.com/2020/01/do-you-know-arduino-sprintf-and-floating-point/
#  -v    # verbose Modus
