Teensy 3.2 : platformio vs. Arduino IDE : strange behavior
Dear experts,
playing with a Teensy 3.2, a Sensor AS5048A, SimpleFOC-Shield V2.0.3 and a Gimbal motor I notice a strange issue, depending on the IDE, but with exakt the identical code:
  • Uploading the code with Arduino IDE the pwm frequency is automatically exactly 25kHz (measured by oscilloscope). Everything works nice and smooth as expected, without noise (due to relatively high frequence).
  • Uploading exakt the same code via platformio the pwm frequence is low, 490Hz to be exactly. This results for sure in big noise, while the regulation is still nice, smooth and as expected.
Here is my code:
MagneticSensorSPI sensor = MagneticSensorSPI(AS5147_SPI, 10);
// voltage set point variable
float target_voltage = 2;
// power supply voltage
// aligning voltage
// align sensor and start FOC
command.add(‘T’, doTarget, “target voltage”);
Serial.println(F(“Set the target voltage using serial terminal:”));
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
float w = sensor.getAngle();
motor.move(w * target_voltage);
And the platformio.ini:
[env:teensy31]
platform = teensy
board = teensy31
framework = arduino
monitor_speed = 115200
lib_deps = askuric/Simple FOC@^2.2
build_flags =
; default: -D TEENSY_OPT_FASTER
; -D TEENSY_OPT_SMALLEST_CODE
; If you want to use Teensy USB Features, you need to add special macro/define using build_flags:
; Teensy — PlatformIO latest documentation
; default: -D USB_SERIAL
; -D USB_FLIGHTSIM_JOYSTICK ; only joystick
; -D USB_EVERYTHING
I thougth that the ‘best’ pwm frequency will be adjusted automatically like described here: BLDCDriver 3PWM | Arduino-FOC
So I assume I have to make an additional appropriate setting in platformio, but WHAT and WHERE?
Any hints are highly appreciated, thank you very much in advance!
Dirk
Hi Dirk,
platformio needs the following option in your platformio.ini file for simplefoc:
lib_archive = false
This should fix the problem you describe.
It is caused by different compiler options/setup in platformio, causing it to misinterpret the weak bindings used on the generic PWM. So you are getting generic PWM, with slow frequencies. ArduinoIDE respects the weak bindings by default. Setting the option above should fix it.
Hi Richard,
simply perfect - you saved my day!
Again, thank you very much for your help and your clear explanation especially.
Based on ‘share and learn’ I learned something again and like to share my fully working code below. Finally my Force-Feed-Back-Flight-Yoke-Project could start.
So, here’s my initial code:
/* Example for Gamecontroller, intended to use for flight simulator (preparation for force feed back).
  • +++Tested and used with the following hardware+++:
  • DEVICE 1: Microcontroller
  • TEENSY 3.2 (3,3V, but 5V tolerant on inputs)
  • special USB feature: emulates HID Joystick / game controller
  • DEVICE 2: Level Shifter
  • connect Teensy 3.2 with SimpleFOCShield V2.0.3 via levelshifter,
  • (also tested without levelshifter, seems to work also…)
  • DEVICE 3: BLDC Shield
  • SimpleFOCShield V2.0.3
  • DEVICE 4: Gimbal Motor
  • iPower GM5208-24, 25.6 ohm phase resistance
  • DEVICE 5: Angle sensor
  • AS5048A, magnetic sensor, details: iPower Motor and SPI Wiring
  • pin connection:
  • | Dev 1 | DEV 2 | DEV 3 | DEV 4 | DEV 5 |
  • | Teensy | Levelshifter | SimpleFOCShield | Motor | Sensor A5048A |
  • | | | A | phase A | |
  • | | | B | phase B | |
  • | | | C | phase C | |
  • | Vin | HV | 5V | | VDD5V, pin 11, green wire |
  • | 3V3 | LV | | | |
  • | 5 | LV1 HV1 | 5 | | |
  • | 6 | LV2 HV2 | 6 | | |
  • | 8 | LV3 HV3 | 8 | | |
  • | 9 | LV4 HV4 | 9 | | |
  • | 10 | | | | CS, pin 1, white wire |
  • | 11 | | | | MOSI, pin 4, black wire |
  • | 12 | | | | MISO, pin 3, yellow wire |
  • | 13 | | | | CLK, pin 2, red wire |
  • | GND | GND GND | GND | | GND, pin 13, purple wire |
// included libraries
#define DEBUGmode // use only for test purpose, reduces performance!
//#define UseCommander // use only for test purpose, reduces performance!
#define MotorConnected
#define Joystickmodus
// MagneticSensorSPI(MagneticSensorSPIConfig_s config, int cs)
// config - SPI config
// cs - SPI chip select pin
MagneticSensorSPI sensor1 = MagneticSensorSPI(AS5147_SPI, 10); // AS50548A in this example, controlled ‘equal’ to AS5147!
MagneticSensorI2C sensor2 = MagneticSensorI2C(0x36, 12, 0x0E, 4); // AS5600 in this example
// alternative constructor (chipselect, bit_resolution, angle_read_register, )
// MagneticSensorSPI sensor = MagneticSensorSPI(10, 14, 0x3FFF);
#ifdef DEBUGmode
unsigned long previousMillis = 0; // obvious
const long interval = 1000; // every 1000ms
const int HIDbuttons = 32; // Teensy as joystick offers 32 buttons
int buttoncounter = 1; // counter for button number
bool btnstate = false; //
int hatangle = 0; // valid values: 0, 45, 90, 135, 180, 225, 270, 315
#endif
#ifdef MotorConnected
// BLDCMotor motor = BLDCMotor(number of polpairs); // typically 11 with gimbal motor
BLDCMotor motor1 = BLDCMotor(11, 25.6); // iPower GM5208-24 has 25.6 ohm phase resistance
//BLDCMotor motor2 = BLDCMotor(11, 11.3); // in preparation, for next stage…
// BLDCDriver3PWM driver = BLDCDriver3PWM(IN_A, IN_B, IN_C, EN);
// set initial point variable
float var_target = 0.5; // initial value, don’t set to high, otherwise initial oscillation of motor might occur!
#ifdef UseCommander
// initiate the commander
void doTarget(char *cmd) { command.scalar(&var_target, cmd); }
#endif
#endif
#ifdef Joystickmodus
float twoPI = 2.0 * 3.14159; // full circle in [rad]
float joy_A_center = -0.632; // Joystick Axis A, depending on physical fixed magnet on shaft orientation
float joy_A_MIN = joy_A_center - 0.9; // Joystick Axis A, lower border limit
float joy_A_MAX = joy_A_center + 0.9; // Joystick Axis A, upper border limit
float joy_A_ABS; // Joystick Axis A, absolute angle in [rad], forces initial calculation
float joy_B_center = -0.512; // Joystick Axis B, depending on physical fixed magnet on shaft orientation
float joy_B_MIN = joy_B_center - 0.1; // Joystick Axis B, lower border limit
float joy_B_MAX = joy_B_center + 0.1; // Joystick Axis B, upper border limit
float joy_B_ABS; // Joystick Axis B, absolute angle in [rad], forces initial calculation
  • HELPER FUNCTIONs *
void fetch_absANGLE()
// this function reads the sensor hardware and
// has to be called before getAngle and getVelocity
#ifndef MotorConnected
sensor1.update();
#endif
// get current sensor Angle, may vary from 0…2*Pi
float curr = sensor1.getSensorAngle();
// get full rotations, positive or negative
int fc = sensor1.getFullRotations();
// calculate absolute value
if (fc >= 0)
// absolute value if positive fullrotations:
joy_A_ABS = curr + (fc * twoPI);
else
// absolute value if negative fullrotations:
joy_A_ABS = -(twoPI - curr) + ((fc + 1) * twoPI);
#endif
  •  SETUP       *
void setup()
#ifdef DEBUGmode
delay(500);
#endif
// initialize sensor one
sensor1.init();
// initialize sensor two
sensor2.init();
motor1.linkSensor(&sensor1);
// power supply voltage, set nominal value from power supply
// OPTIONAL: Max DC voltage allowed
// if set to low oscillation might occur, if set to high overheating of motor and driver might occur
driver.voltage_limit = 24.0; // optional
// set driver PWM frequency, OPTIONAL: BLDCDriver 3PWM | Arduino-FOC
// default pwm frequency in SimpleFOC library for TEENSY 3.2 should be 50kHz.
// Mesuring with oscilloscope results in only 25kHz default.
// In any case: don’t forget to add ‘lib_archive = false’ to platformio.ini,
// otherwise the normal pwm frequency of 490Hz will be used!
// driver.pwm_frequency = 50000; // optional
// finally driver initialization
// link driver with motor
motor1.linkDriver(&driver);
// set voltage for sensor align, must be at least to move motor during sensor ini
motor1.voltage_sensor_align = 5.0;
motor1.foc_modulation = FOCModulationType::SpaceVectorPWM;
motor1.controller = MotionControlType::torque;
// optional, not tested yet:
// motor1.PID_velocity.P = 1;
// motor1.PID_velocity.I = 1;
// motor1.PID_velocity.D = 1;
motor1.init();
motor1.initFOC();
#ifdef UseCommander
#endif
#endif
Serial.println(“Sensor ready”);
fetch_absANGLE();
#endif
  •  LOOP        *
void loop()
motor1.loopFOC();
// reads current angle
float w = sensor1.getAngle();
sensor2.update(); // neccessary if not loopFOC running for this motor/sensor !?
float z = sensor2.getAngle();
//motor.move(w * var_target); // IF Gimbal motor rotates in other direcdtion
motor1.move(-(joy_A_center - w) * var_target);
#ifdef UseCommander
#endif
#endif
fetch_absANGLE();
if ((joy_A_ABS >= joy_A_MIN) && (joy_A_ABS <= joy_A_MAX)){
int jsv = map(joy_A_ABS, joy_A_MIN, joy_A_MAX, 0, 1023); // joystick values typically vary from 0…1023
Joystick.X(jsv);
Joystick.Y(jsv);
Joystick.Z(jsv);
Joystick.Zrotate(jsv);
Joystick.sliderLeft(jsv);
Joystick.sliderRight(jsv);
#endif
#ifdef DEBUGmode
unsigned long currentMillis = millis();
if (currentMillis - previousMillis >= interval)
btnstate = !btnstate; // toggles state
 Joystick.button(buttoncounter, btnstate);
if (btnstate == false){
if (buttoncounter < HIDbuttons){
  buttoncounter++;}
  else{buttoncounter =1;}
Serial.print("Absolute angle [rad]:");
Serial.print(joy_A_ABS);
Serial.print("\t\t");
Serial.print("joy_A_MIN:");
Serial.print(joy_A_MIN);
Serial.print("joy_A_center");
Serial.print(joy_A_center);
Serial.print("joy_A_MAX:");
Serial.println(joy_A_MAX);
Serial.print("Sensor2:");
Serial.println(z);
Joystick.hat(hatangle);
if (hatangle == 360){
hatangle =0;
}else{hatangle = hatangle +45;}
previousMillis = currentMillis;
#endif
Processing: VID_20211101_190252.mp4…
Best regards,
Dirk
