SimpleFOC stepstick
Stepstick MAX is fully assembled now. STM32 is running fine, but I haven’t gotten the driver to run yet. The charge pump pin shows a 100KHz square wave, so it is awake, but fault pin reads 0 despite the pullup resistor, so it’s not happy about something. According to the datasheet, the fault conditions are thermal (above 165C), undervoltage (VM below 4V) and overcurrent. But everything is cool, VM is 7.5V from my usual 2S lipo, and I can’t measure any shorts between the output pins and VM or ground or eachother. I also double checked that fault isn’t shorted to ground. No clue what’s wrong.
While testing on a Gooser4 the other day, I made a dirt cheap magnetic encoder for my NEMA23 steppers using a 3x4mm cylindrical magnet, two 49E linear halls and some 3D printed bits. It only clicks into some holes in the motor by friction, but stays on surprisingly well, and I’ll give it some hot glue for extra security. These motors run cool, so no worries about it melting.
So far I’ve gotten it to hold within ±1/800 of a revolution while harassing it, using some fancy lookup table calibration and direct angle PID without cascaded velocity PID. That’s ±5 micrometers with the 4mm ballscrews on my CNC, so maybe good enough, but hopefully I can improve it further.
Success! I never was able to measure any shorts, but I decided to try reflowing it again just for the heck of it, and it worked. Connectors are a bit melted now, but that’s ok.
I had given up on my closed-loop CNC project due to the wires running between the RP2350 brain and the motor driver step pins picking up noise and causing spurious step interrupts, but stepstick can plug into my original GRBL board which should hopefully have better grounding.
I have to use HybridStepperMotor with 3 channels for now due to my incorrect choice of timer channels (can either use two complementary pairs or three non-complementary channels, whereas StepperMotor needs four non-complementary). I could write some code for the dual complementary stepper scheme I had in mind, but since I only spent a few bucks on bare boards I’ll probably just order the new version I made with the proper arrangement. And the old ones are still perfectly usable for 3-phase brushless motors.
EDIT: I forgot I never actually uploaded the images for the new version.
EDIT2: Updated images after discovering a minor error (had to swap EN_DRV and HOME pins for I2C to work, and add BOOT0 touchpad since it was no longer accessible as a pin).
More refinements! This baby is ready to order.
  • Swapped home and reset pins, so home matches standard sensorless homing pinout (not sure how I got that wrong before)
  • Outputs and current sense are now in 1,2,3,4 order instead of 1,2,4,3 like MAX22213 calls them (note 1)
  • Changed resistor array to 3.9k with 1% tolerance (note 2)
  • Replaced reset pullup with 100nF capacitor to ground (recommended by STM, and opens up the power ground path on the top layer)
  • Swapped the programming connector + and - pins to further improve power ground path
  • Added a 3V via for the STM32’s VDDA, to somewhat isolate its filter capacitors from the power supply capacitors (theoretically could reduce ADC noise a bit)
  • Removed MAX from the name on the schematic (the version number is informative enough)
Note 1: Functionally, this was just swapping which driver pins PWM3 and PWM4 connect to and renaming the nets. The routing is a bit more crowded now, but I’ve been annoyed with that naming scheme from the beginning. Confusing for BLDC motors and not particularly helpful for steppers either.
Note 2: If I’m understanding the driver datasheet properly, the current sense voltage (what the ADC reads) must never exceed 2.2V, so the 4.7k resistors would damage it at 3.5A. 3.9k is safe up to 4.2A, which gives about 10% safety buffer beyond the driver’s rated peak 3.8A (3.8A gives 1.98V, so 710 ADC units per amp). I wanted to use the STM32’s VREFBUF to provide 2V reference voltage for better resolution, but sadly it’s not available on the 32-pin package. I could use the driver’s 1.8V VDD pin to power the STM32’s ADC, but then it wouldn’t be possible to read higher voltages (linear halls no longer usable).
Unfortunately I’ve discovered that the current sense output on MAX22213 is unidirectional. Should I cut my losses and abandon the project, or make it work as best I can?
Stepper motors can be made to work fine with 4-channel current sense, though it will require custom ADC configuration since SimpleFOC only does up to 3 channels.
But BLDC can never do proper FOC since half the time only one channel gives usable output. If I assume there’s no phase lag, I could estimate the other two from the known voltage angle. But the discontinuity at the transition between each zone would likely be bad. So I’m probably restricted to using DC current mode, and estimating that while in single-sensor territory.
Here’s what the current readings look like compared to the output voltages (open loop velocity, so perfect sine waves). Their amplitudes vary by quite a lot. They match the sine waves more accurately if I give them a bit of upward offset too, but I’m not sure how to go about calibrating for that.
UPDATE:
It looks like DC current mode will work, at least at low speed. The basic procedure is to divide the current by a sine wave to normalize it, and select whichever phase is closest to its negative peak. Then to reduce discontinuity at the transition from one phase to the next, I interpolate between two phases’ readings in the ±15° around the transition point (white segments in the DC current line at the bottom). The gray zigzag is electrical angle.
Here is the code:
  // The electrical revolution is divided up into 12 sectors of 30 degrees each.
  // When motor.electrical_angle is 0, phase A voltage is 0 and headed toward negative.
  // At motor.electrical_angle = 30 degrees, phases C and A have equal magnitude.
  // Sector 0 starts at motor.electrical_angle = 15 degrees and ends at 45 degrees,
  // and as the angle progresses through that range, the output fades from C's reading to A's reading.
  // The next 3 sectors use A alone, then fade from A to B, and so on.
  // sector -> phases used
  // 0   -> C,A
  // 1-3 -> A
  // 4   -> A,B
  // 5-7 -> B
  // 8   -> B,C
  // 9-11-> C
  // Normalize the current for each phase, so they have constant value rather than sinusoidal variation
  PhaseCurrent_s c = currentSense.getPhaseCurrents();
  float phaseCurrent[3] = {0,0,0};
  for (int i = 0; i < 3; i++) {
    float electricalAngle = _normalizeAngle(motor.electrical_angle - i*_2PI/3);
    if (electricalAngle > _2PI*14/360 && electricalAngle < _2PI*166/360) // Reading is valid from 0 to 180 degrees, but onlt 15 to 165 is actually used
      phaseCurrent[i] = ((float*)&c.a)[i] / _sin(electricalAngle);
  // Select the phase with the highest magnitude for the electrical angle, and interpolate if near the boundary between two phases
  float electricalAngle = _normalizeAngle(motor.electrical_angle - (_PI/12) * _sign(motor.current_sp)); // Offset by 15 degrees so 0 corresponds to sector 11-0 boundary
  int intAngle = electricalAngle * (65536.0f*3.0f/_2PI); // Range is now 0-65536 for 120 degrees, 0-196607 total
  int sector = intAngle >> 14; // Range 0-11 (30 degrees per sector)
  int phase = sector >> 2;
  float estimatedCurrent = phaseCurrent[phase];
  if ((sector & 3) == 0) {
    if(--phase < 0) phase = 2;
    float c0 = phaseCurrent[phase], c1 = estimatedCurrent;
    float blend = (float)(intAngle & 0x3fff) / 16384.0f; // Interpolate between the two as the angle progresses through the sector
    estimatedCurrent = c0 + (c1 - c0) * blend;
I hardcoded some gain and offset calibration to make the currents match closer to the voltage sine waves. Without that, the DC line steps up and down with the phase magnitudes, and the interpolation areas are slightly higher magnitude than they should be. Calibrating the gain would be no problem, but I don’t know how to sort out the offset from it. I may just go with a hardcoded 50mA offset, but I’ll need to assemble more of them and test to see how much variation there is.
For high speed, I have two potential approaches, both of which rely on detecting the peak of the sine wave, where the normalized current is equal to the raw measurement.
  1. Phase lag equal to the difference between the electrical angle where the measured current peak happened and the electrical angle where the voltage peak would be in open loop mode
  2. Each time a peak is detected, plug the current value into the equation here to estimate the phase lag.
I’ll try #1 first, since it’s more direct, and doesn’t require knowing the inductance. Either way, the phase lag will only be updated 3 times per electrical revolution. But since it’s only needed when the motor is spinning fairly fast, it will probably be fine.
UPDATE2:
I’ve gone about it all wrong. During the phase transition areas where two currents are good, the third phase is also known via the zero-sum rule so the DC current can be calculated exactly. Plus I can calculate the phase lag correction to use until the next two-phase window so the DC estimation from a single phase should be very accurate at any speed.
I did not abandon the project, it’s just taken a great deal of prodding and pondering to understand. Here are the conclusions:
  • Deadtime was causing the first 40mV of commanded voltage to be ineffective, which messes with the linearity of current to voltage.
  • The current sensors don’t start outputting until around 150mA.
Between those two things, all my efforts to calibrate and estimate the current were in vain.
Adding deadtime compensation makes it really easy, but that has to be done in the library, and unless I can come up with a cleaner/more efficient way to do it, I’m reluctant to add it.
I can still calibrate the current sense without it by adding the appropriate voltage for 100ns when calling setPwm during calibration. I thought I’d also need to account for the “lost” voltage when estimating <150mA currents from voltage while running, but I seem to get better results without it.
The sensors give a clean 0V when current is positive now, unlike the plots in my previous post where they’d give a small voltage during the highside period. My only guess is the 4.7k resistors were too high. I’m using 2.2k now which guarantees that the sense voltage will never exceed the 2.2V abs. max even in HFS mode, and keeps within the 1.1V regular max without HFS.
I think it will be possible to run foc_current mode, although I haven’t tested with a sensor yet, and couldn’t get sensorless observer to run.
Here is my getPhaseCurrents() for BLDC, which calculates the phase lag when two currents are measurable, estimates the other two phases when only one is measurable, or estimates all three from voltage if none are measurable.
    PhaseCurrent_s current = {current_a, current_b, current_c};
    if     (a_valid&&b_valid) current.c = -current.a-current.b;
    else if(a_valid&&c_valid) current.b = -current.a-current.c;
    else if(b_valid&&c_valid) current.a = -current.b-current.c;
    else { // Reconstruct all three currents from one known, on the assumption that they are all sinusoidal and spaced 120 degrees
      if (motor->shaft_velocity < low_speed_threshold)
        last_known_lag = 0;
      float magnitude, angle = _normalizeAngle(motor->electrical_angle + last_known_lag);
      const float sa = _sin(angle), sb = _sin(angle-_2PI/3), sc = _sin(angle-_2PI*2/3); // Each phase's sine wave at current angle
      if     (a_valid) magnitude = current.a/sa;
      else if(b_valid) magnitude = current.b/sb;
      else if(c_valid) magnitude = current.c/sc;
      else { // No measurable current, calculate from voltage
        BLDCMotor *bldc = static_cast<BLDCMotor*>(motor);
        if(angle < _PI/6 || angle >= _2PI*2/3+_PI/6)
          magnitude = ( current.c = (bldc->Uc-(bldc->Ua+bldc->Ub)/2)/resistance )/sc;
        else if(angle < _2PI/3+_PI/6)
          magnitude = ( current.a = (bldc->Ua-(bldc->Ub+bldc->Uc)/2)/resistance )/sa;
        else
          magnitude = ( current.b = (bldc->Ub-(bldc->Ua+bldc->Uc)/2)/resistance )/sb;
      return (PhaseCurrent_s){sa*magnitude, sb*magnitude, sc*magnitude};
    // Update current vector angle
    ABCurrent_s ab = getABCurrents(current);
    last_known_lag = fmod(_atan2(-ab.alpha, ab.beta) - motor->electrical_angle, _2PI);
    if(last_known_lag >= _PI) last_known_lag -= _2PI;
    else if(last_known_lag <= -_PI) last_known_lag += _2PI;
    return current;
And here are some plots of voltage and current while rotating at 0.2rad/s open loop, one with low voltage where at most one current is measurable at any give time and sometimes all currents are estimated from voltage, and another where at least one current is measurable at all times. Strangely, there seems to be a phase shift one way on red and the other way on green and blue, which causes the estimation of positive green to be too high and blue too low.
I only read the last few posts, but I wonder how the half-a$$ed (pun intended) current measurement compares to estimated_current? Is it worth it shoehorning current sensing HW on the PCB when most of the time you can’t measure current?
You’re probably right. I thought it would work perfectly for steppers at least, since one end of each coil always has a negative current, but even that will require estimating due to the 150mA threshold. And with the 3.8A overcurrent protection, there shouldn’t be too much risk of sudden death when running estimated_current mode like there is with most drivers.
It’s also possible to use the current readings for software overcurrent protection at motor.current_limit while running in voltage control or estimated_current mode. I did that when I tried (and failed) to convert my CNC machine to closed-loop with Gooser.
    // Current limiting
    if (fabsf(currentSense.getDCCurrent()) > motor.current_limit)
      motor.voltage_limit = fabs(motor.voltage.q) - dt*100; // Decrease voltage at 100V/s until current is below limit
    else {
      motor.voltage_limit += dt*20; // Recover at 20V/s
      if (motor.voltage_limit > driver.voltage_power_supply * 0.58f)
        motor.voltage_limit = driver.voltage_power_supply * 0.58f;
I’ve encountered a new mystery to torment me… HFS mode is supposed to double the current reading to get more resolution at low current, so I thought I’d give it a try incase it would help with the 150mA minimum. While it does start outputting slightly sooner (maybe 110mA?) the overall range is only about 1.6x higher, which calls into question the validity of the normal mode range. I need a known-accurate current sensor to measure simultaneously with it and see what’s really going on.
Can I read more about that in another thread?
Lately I tried to reach the same torque with FOC as with a block commutating driver. I had to allow a higher motor.voltage_limit (0.95* driver.voltage_power_supply) and allowed to run at peak current for a short period of time.
I wrote some here about my initial experiments trying to get ultra-precision readings with a few cents worth of hardware I had on hand (not quite good enough, but @runger saved the day sending me some proper diametric magnets and sensors to use), but I don’t think I documented the rest:
  • Struggled getting grblHAL to compile for RP2350
  • Was tormented by a tin whisker that eventually fried the SCL pins on both STM32’s
  • Gave up after sporadic triggering of step interrupts
I had a rat’s nest of tiny wires soldered to the Gooser due to not enough GPIO accessible, so it would be more likely to work with the latest version, which could have ground wires together with each signal wire to hopefully minimize EMI pickup, and use STM32’s hardware step/dir counting which has some spike filtering.
I’m pretty happy as it is since I can still use the sensors and RP2350 to display the axis positions on a little OLED, and use the buttons I added to zero the positions and do probing operations more quickly than I could before. But I probably will try closed-loop with SimpleFOC Stepstick since it should be relatively easy just plugging it into the GRBL board and swapping back if it doesn’t work out.
I thought maybe the resistance of the BLDC I’ve been using is too low to get accurate readings, so I decided to test some higher resistance things today:
  • 2 ohm power resistor. No current measurable, I think due to no inductance (sampling at lowside center, both phases are 0V at the time)
  • NEMA 14 pancake stepper with 16 ohm resistance, so presumably very high inductance.
Due to the high resistance (and thus voltage), the contribution of deadtime is insignificant so calculated currents should be accurate. This time HFS works as it should. Output begins at 72mA, whereas normal mode begins at 140mA, and both increase linearly, with HFS increasing at twice the rate. So the raw ADC reading is not 2x, but once you’ve calibrated the offsets, it is.
So it looks like the normal mode BLDC current is probably accurate since the threshold current is about the same, but HFS doesn’t work well with it for some unknown reason, so I’ll just go back to ignoring HFS. I should be able to auto-calibrate the resistance for estimated_current mode, so that’s good. I’d like it to be as “plug-and-play” as possible for general 3D printer and CNC machine building, and not need skilled tuning of all the parameters for every motor, so hopefully I can auto-calibrate kv as well.
IMHO it could be done in torque mode. Just set a low phase voltage e.g. 1V and measure no load speed…
I’ll be wearing my dunce cap for a long time after this. It turns out the 150mA threshold was not that the current sensors weren’t outputting anything, but rather that the ADC couldn’t read values smaller than ~50mV because I didn’t run the extremely simple built-in calibration procedure (just set the ADC_CR_ADCAL bit and wait until it clears itself).
I’d heard of it before, but somehow never thought to run it until I was working on Gooser and got nonlinear results from reading the bus voltage divider. I calculated that it had a ~50mV offset, probed the pin to verify, probed the current sensors and saw it there as well, and then thought to calculate what stepstick’s current sense output should be at 150mA, and that was also ~50mV. So I searched “STM32 50mv adc” and got several results saying to run the calibration.
But now that the low range is visible, I can see that the 0 amp reading seems to be influenced by other channels like in post #64. After some sleuthing, it appears the voltage doesn’t have quite enough time to settle when using the shortest sampling time option, so after sampling a channel with high value, sampling a zero shows some remnant voltage. Likewise, high values are dragged down (possibly the source of the apparent phase shift I was seeing in post #65). Increasing sample time from 2.5 to 12.5 cycles eliminates it, but the 6.5 cycle option is probably good enough and doesn’t reduce the maximum PWM duty as much.
HFS mode remains a mystery, giving 50-60% higher reading when the datasheet looks like it should be 95-100% higher, so I’d still like to get a simultaneous current measurement with some other device to verify which mode (if either) gives the true current.
Here is the current sense class. It references DriverType::DC which doesn’t exist yet, but you can either comment out that line or add DC in your FOCDriver.h.
I’ve been running it on my CNC mill for a while without issue, using 5V step/dir signals from the GRBL Nano, SPI encoders, and I2C communication with my DRO/manual controls.
I may still try making a stock firmware that can be configured for all types of motor and encoder without having to recompile, but it was looking pretty tricky when I started on it before.
I won’t be able to produce a significant quantity of these until my pick-and-place is done (could be a while), and double-sided assembly by JLC is prohibitively expensive and lacking the MAX22213, so it’s pretty much DIY for now. Or could try other PCB services, but I’ve never used any others so I’m not sure how they handle component selection. The driver placeholder is the same part number as the STM32, so may need to be changed to some other placeholder so they can be selected independently.
My CNC has a LunYee 32bit GRBL 4-axis CNC controller. You’d say the stepstick drivers would fit there too?
Right now I use external drivers in open loop (TB6600) with 40V. What is the voltage/current limit of the stepsticks?
The driver’s voltage range is 4.5V to 36V, so sadly you won’t be able to use your current power supply. But the low voltage section can run on 3.3V to 5V, so with a 36V supply you should be good to go. Make sure your encoders can run on 3.0V, since that’s what the onboard regulator outputs (otherwise I would have had to make separate versions for 3.3V and 5V, since the regulator needs to drop some voltage and there’s no space for anything fancy).
I’ve only done current testing without a heatsink, and in that case around 1 amp from getDCCurrent is the limit for continuous use, so 2 should be ok with heatsink and fan.
But keep in mind that you’ll typically be using vastly less current than with open loop since it’s proportional to the actual load, whereas closed loop has to run with a safety margin beyond what you’ll ever actually need. And thanks to having temperature sense, you can reduce the current limit as the temperature rises, making it safe to allow high peak current in normal use. Worst case you’re down to 2A and the motor slows down, and catches up after the load lightens. Theoretically you could report such a situation to the controller so it can reduce the feedrate to keep all the other motors properly coordinated with the one that’s suffering.
I remembered, Gooser can go up to 40V. It will have to use HybridStepperMotor, so lower effective voltage to the motors, but could save you having to buy a new power supply. It will be at the limit of the buck converters, but there are plenty of compatible 60V mosfets to pick from. BSZ040 looks the best, and should be around 5-6 amps continuous without cooling. Chinese brands with similar specs are about 1/5 the price (25 cents versus $1.25) but IME they’re usually exaggerated by about 2x, so that would probably be 3 amps. Still 3x as much as stepstick, though.
I had trouble with v5.5 on my CNC due to insufficient I/O, but 5.8 is designed so the wiring can be nice and clean. The encoder connectors will be used for en,step,dir,gnd, and programming connector for two SPI encoders. The communication connector remains free for other purposes.
Hello everyone, I was about to start designing a discrete stepper driver to use FOC on my Ender 3, and i just stumbled on this thread. Is this board ready to be built and tested? If so i’d love to try it before / instead of building my own!
btw nice build @dekutree64
Yep, the design is pretty well verified now. I’ll change the status to complete on OSHWLab.
The only nagging issues are the HFS pin not giving a full 2x the current reading (not really a problem, just don’t use it), and VDD feeding power out to the motherboard when programming over ST-link. It doesn’t cause any trouble on mine, but might on motherboards with a large number of drivers, which would all start pulling power through the little VDD line and overheat it. I can’t use a diode because it would drop too much voltage on 32-bit motherboards where VDD is 3.3V.
Thanks for the answer, cant wait to start building it!
