Hi
I’m currently working on the Giga with SimpleFoc. At the moment, SimpleFoc will fall back to the default driver, using analogWrite() on the Giga. This causes the buzzing noise, since Arduino’s Mbed-driver sets the PWM frequency to 500Hz.
I tinkered around with STM32 and Portenta code, but with both, the Giga hangs after a certain number of motors being initialized - I did not yet had time to seriously debug the issue. For the moment, I’m using a hacky Mbed implementation:
#include <drivers/hardware_api.h>
3 PWM BLDC driver class
https://github.com/arduino/ArduinoCore-mbed/blob/main/cores/arduino/wiring_analog.cpp
https://github.com/arduino/mbed-os/blob/master/drivers/include/drivers/PwmOut.h
https://github.com/arduino/mbed-os/blob/master/drivers/source/PwmOut.cpp
https://github.com/arduino/mbed-os/blob/master/targets/TARGET_STM/pwmout_api.c
https://github.com/STMicroelectronics/stm32h7xx_hal_driver/blob/master/Src/stm32h7xx_hal_tim.c
class MbedDriver3PWM : public BLDCDriver
public:
MbedDriver3PWM(int phA, int phB, int phC, int en1 = NOT_SET, int en2 = NOT_SET, int en3 = NOT_SET)
: m_pwm{ 0, 0, 0 }, m_pwmPin{ phA, phB, phC }, m_pwmEnablePin{ en1, en2, en3 }, enable_active_high(true) {
voltage_power_supply = DEF_POWER_SUPPLY;
voltage_limit = NOT_SET;
pwm_frequency = NOT_SET;
int init() override {
for (int i = 0; i < 3; i++) {
pinMode(m_pwmPin[i], OUTPUT);
if (_isset(m_pwmEnablePin[i]))
pinMode(m_pwmEnablePin[i], OUTPUT);
m_pwm[i] = new mbed::PwmOut(digitalPinToPinName(m_pwmPin[i]));
m_pwm[i]->period_us(40); // 25kHz
m_pwm[i]->write(0.0f);
// sanity check for the voltage limit configuration
if (!_isset(voltage_limit) || voltage_limit > voltage_power_supply)
voltage_limit = voltage_power_supply;
initialized = true;
return 0;
void disable() override {
setPwm(0, 0, 0);
// disable the driver - if enable_pin pin available
if (_isset(m_pwmEnablePin[i])) digitalWrite(m_pwmEnablePin[i], !enable_active_high);
void enable() override {
if (_isset(m_pwmEnablePin[i])) digitalWrite(m_pwmEnablePin[i], enable_active_high);
// set zero to PWM
setPwm(0, 0, 0);
void setPwm(float Ua, float Ub, float Uc) override {
Ua = _constrain(Ua, 0.0f, voltage_limit);
Ub = _constrain(Ub, 0.0f, voltage_limit);
Uc = _constrain(Uc, 0.0f, voltage_limit);
dc_a = _constrain(Ua / voltage_power_supply, 0.0f , 1.0f);
dc_b = _constrain(Ub / voltage_power_supply, 0.0f , 1.0f);
dc_c = _constrain(Uc / voltage_power_supply, 0.0f , 1.0f);
m_pwm[0]->write(dc_a);
m_pwm[1]->write(dc_b);
m_pwm[2]->write(dc_c);
virtual void setPhaseState(PhaseState sa, PhaseState sb, PhaseState sc) override {
// disable if needed
if (_isset(m_pwmEnablePin[0]) && _isset(m_pwmEnablePin[1]) && _isset(m_pwmEnablePin[2])) {
digitalWrite(m_pwmEnablePin[0], sa == PhaseState::PHASE_ON ? enable_active_high : !enable_active_high);
digitalWrite(m_pwmEnablePin[1], sb == PhaseState::PHASE_ON ? enable_active_high : !enable_active_high);
digitalWrite(m_pwmEnablePin[2], sc == PhaseState::PHASE_ON ? enable_active_high : !enable_active_high);
private:
mbed::PwmOut* m_pwm[3];
int m_pwmPin[3];
int m_pwmEnablePin[3];
bool enable_active_high;
Feel free to have a look at my WIP: reufer/gigafoc (github.com)
BTW: I also have 3 pieces of P1A hardware left, if anyone is interested - however, only four motors are usable, because I used TIM2 on one instance, which is not available on the Giga. This should be fixed in P1B, which I will going to order, as soon as all components are available on JLCPCB.
