Simplefoc 2.1.1 vs 2.2.3 differences question following up
Hi buddy,
this is following up thread of Simplefoc 2.1.1 vs 2.2.3 differences
I made a self-made board to program Simplefoc 2.1.1, everything is good. When I used 2.2.3 with the suggested log output, I still met something wrong, very high-power consumption of the driver board and can’t control by UART CMD. I can get below log.
(I add below line
// link current sense and driver
current_sense.linkDriver(&driver) in main.cpp with simplefoc v2.2.3 )
Here are my driver pins
Here is my lib configuration log.
Do you have some comments?
In this debug output, your pole pair check is failing - estimated PP == 1024 - that’s much too high, you motor has 7PP? This indicates the motor did not move or did not move much, or the sensor is having a problem.
Which sensor are you using?
Could you share your platformio.ini ?
Hi Runger,
I am using AS5047P, 4 line spi interface.
Yes, of course. shown below.
As I said, using simplefoc-2-1-1, everything is good.
By the way, during my debug work with simplefoc-2-1-1, very few times I also met estimated PP != 7, and motor is not run correctly, angle output is not correct…(this is cause by I set motor.phase_resistance = 0.6; // [Ohm], actually it should be 2.6 ).
This actually all looks ok… hmmm… you’re initialising the sensor with 10 bit precision, but actually it is 14. Maybe that’s the issue?
Could you also try with the 2.3.0 version of the library? There have been some bug-fixes.
Could you also try initialising the sensor like this:
MagneticSensorSPIConfig_s myAS5047SPIConfig = {
  .spi_mode = SPI_MODE1,
  .clock_speed = 1000000,
  .bit_resolution = 14,
  .angle_register = 0x3FFF,
  .data_start_bit = 13,
  .command_rw_bit = 14,
  .command_parity_bit = 15
MagneticSensorSPI sensor = MagneticSensorSPI(myAS5047SPIConfig, PB15);
Hi Runger,
I tried 2.3.0, and modified AS5047P’s resolution
MagneticSensorSPI sensor = MagneticSensorSPI(PB15, 14);
I still have problems with v2.3.0, sometime PP check fails, power consumption is very high.
sometime PP checks ok, but the motor is not running to the targeted angle (encoder data is also not correct), power consumption is high.
Here is the issued current and INA240A2 PIN 8 output (inline current output looks good), but total driver board power consumption is high, and motor is hot.
Below is v2.1.1 performance with current foc control.
Here is my v2.3.0 code, I am wondering, is there something motor parameter configuration which is not correct?
// Motor instance
BLDCDriver3PWM driver = BLDCDriver3PWM(PB4, PB5, PB0, PB12);
// current sensor
InlineCurrentSense current_sense = InlineCurrentSense(0.01f, 50.0f, A0, A1);
// angle,velocity set point variable
float target_velocity = 0;
float target_angle = 0;
void doTarget(char *cmd)
{ command.scalar(&target_velocity, cmd); }
void doMotor(char* cmd)
{ command.motor(&motor, cmd); }
void setup()
_delay(100);
SIMPLEFOC_DEBUG("Hello world!");
// encoder.enableInterrupts(doA, doB);
// link current sense and the driver  2.2.0 above required
// aligning voltage [V]
motor.voltage_sensor_align = 1.5;
// if you are not using aligning voltage, you can set current limitation
motor.phase_resistance = 2.6; // [Ohm]
// motor.velocity_index_search = 3;
// motor.torque_controller  = TorqueControlType::voltage;
// motor.controller = MotionControlType::torque;
// motor.target = 0.5;
// internal res is 0.35 ou maximum current is 2A
// maximum volts is 0.7
// this is used for open loop
// motor.voltage_limit = 0.7;
// motor.velocity_limit = 20;
motor.target = 13; //
// contoller configuration
motor.PID_velocity.P = 0.01;
motor.PID_velocity.I = 0.003;
// motor.PID_velocity.D = 0.001;
motor.LPF_velocity.Tf = 0.01;
motor.voltage_limit = 1.5;
motor.current_limit = 0.8; // Amps
// angle P controller
motor.P_angle.P = 23;
motor.P_angle.D = 0.01;
motor.monitor_downsample = 1; // setting sample rate, can up to 100+
motor.monitor_variables = _MON_TARGET  | _MON_CURR_Q | _MON_CURR_D | _MON_VEL | _MON_ANGLE;
//motor.monitor_downsample = 100; // set downsampling can be even more > 100
//motor.monitor_variables = _MON_CURR_Q | _MON_CURR_D; // set monitoring of d and q currents
current_sense.init();
// invert phase b gain
current_sense.gain_b *=-1;
// skip alignment
// current_sense.skip_align = true;
// motor.target = 13;
// 订阅电机至commander
command.add('M', doMotor,"motor");
// command.add('T', doTarget, "target_velocity");
Serial.println("Set the target using serial terminal:");
_delay(300);
void loop()
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
// motor.move(target_velocity);
// test current
//PhaseCurrent_s currents = current_sense.getPhaseCurrents();
//float current_magnitude = current_sense.getDCCurrent();
//Serial.print(currents.a * 1000); // milli Amps
//Serial.print("\t");
//Serial.print(currents.b * 1000); // milli Amps
//Serial.print(currents.c * 1000); // milli Amps
//Serial.println(current_magnitude * 1000); // milli Amps
Hello Runger,
This looks stranges, Any comments or suggestions ?
Hey, is this one also related to the broken INA chip, or is it a different issue?
Hey Runger,
The above description is with new INA chip. already replaced the broken INA chip.
Hello ? Any further comments ?
I have found a bug to do with the initialization of the phase inductance…
I’ve fixed it on the dev branch. It’s perhaps an explanation for the difference, I’m not sure…
Hi Runger,
That’s a good news : )
Feel free to let me know when you are fixed the bug, I will help to verify on my HW : )
Hi @kuqn ,
Yes, it is already on the dev branch:
To use it you would have to git clone the dev branch from GitHub, and use the cloned version in ArduinoIDE/PlatformIO. There are instructions online for doing it.
Otherwise, if you prefer to wait it will be part of the next release of SimpleFOC.
