Running external IPM intelligent power module
Has anyone used this library to run a hv bldc motor that runs through an external intelligent power module? i am trying to find a solution to run a fan and compressor from a mini split condenser.
Hi @Bryce1263
Welcome to the forum.
Yes. We have successfully tried. Please check out these threads.
https://community.simplefoc.com/t/igbt-driver-nfam5065l4bt-simplefoc-board/1087
https://community.simplefoc.com/t/igbt-driver-dev-board/1080
Is that what you had in mind?
Thanks! I posted to this forum with my current project.
I see. I was under the impression you want to run an integrated module, or design your own module, not an entire pre-fabricated board. It would be almost impossible to find help with that here on this board. At the very least you need the schematics for the pre-fabricated board.
Thanks for the help. This is only a two later board so it could be feasible for me to reverse engineer the schematics. At least for what’s driving these ipm modules.
