Hello, Friend.
My Motor Don’t run and I could have cooked my motor almost.
I try to set up FOC testing environment using Arduino UNO + DRV8302 + AS5147 + XXD2217 KV960 BLDC.
I Connect AS5147 to UNO using normal UNO’s SPI pin(cs-10, 11,12,13) and give 5v and gnd.
And I upload angle_control.ino(example) to UNO after mapping DRV8302’s PIN as below code.
My motor has 14 magnet, So I type 7 in BLDCMotor instance.
But, Motor don’t run. Plz Help Me~
* Position/angle motion control example
* Steps:
* 1) Configure the motor and magnetic sensor
* 2) Run the code
* 3) Set the target angle (in radians) from serial terminal
#define EN_GATE 8
#define M_PWM 6
#define M_OC 5
#define OC_ADJ 7
MagneticSensorSPI sensor = MagneticSensorSPI(AS5147_SPI, 10);
//MagneticSensorI2C sensor = MagneticSensorI2C(AS5600_I2C);
BLDCDriver3PWM driver = BLDCDriver3PWM(9, 2, 3, 8);
// angle set point variable
float target_angle = 0;
// DRV8302 specific code
// M_OC - enable overcurrent protection
pinMode(M_OC,OUTPUT);
digitalWrite(M_OC,LOW);
// M_PWM - enable 3pwm mode
pinMode(M_PWM,OUTPUT);
digitalWrite(M_PWM,HIGH);
// OD_ADJ - set the maximum overcurrent limit possible
pinMode(OC_ADJ,OUTPUT);
digitalWrite(OC_ADJ,HIGH);
// contoller configuration
motor.PID_velocity.P = 0.2f;
motor.PID_velocity.I = 20;
motor.voltage_limit = 6;
// angle P controller
motor.P_angle.P = 20;
motor.velocity_limit = 20;
motor.useMonitoring(Seria1);
// align sensor and start FOC
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
motor.move(target_angle);
// motor.monitor();
Hey @DennyKing,
Using drv8302 chip can easily be fatal for your motor, so please take this step by step.
Angle control mode is the most complex one, and you should start with torque control ( using voltage).
However, your code should still work, the only big issue I see in it is the pin 2 is not pwm pin. You’ll have to use Arduino uno’s pwm pins for the driver 4,5,6,9,10 or 11.
Thanks for your reply.
I follow your recommandtions. So I changed settings.
* Comprehensive BLDC motor control example using encoder and the DRV8302 board
* Using serial terminal user can send motor commands and configure the motor and FOC in real-time:
* - configure PID controller constants
* - change motion control loops
* - monitor motor variabels
* - set target values
* - check all the configuration values
* check the https://docs.simplefoc.com for full list of motor commands
// DRV8302 pins connections
// don't forget to connect the common ground pin
#define INH_A 3
#define INH_B 5
#define INH_C 6
#define EN_GATE 8
#define M_PWM A1
#define M_OC A2
#define OC_ADJ A3
// Motor instance
BLDCDriver3PWM driver = BLDCDriver3PWM(INH_A, INH_B, INH_C);
// commander interface
motor.voltage_limit = 12;
// angle loop controller
// angle loop velocity limit
motor.velocity_limit = 50;
// monitoring port
// initialise motor
motor.target = 2;
// define the motor id
command.add('A', onMotor, "motor");
Serial.println(F("Full control example: "));
Serial.println(F("Run user commands to configure and the motor (find the full command list in docs.simplefoc.com) \n "));
Serial.println(F("Initial motion control loop is voltage loop."));
Serial.println(F("Initial target voltage 2V."));
In the serial monitor, like this.
MOT: Monitor enabled!
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: sensor_direction==CCW
MOT: PP check: fail - estimated pp: 16383.95
MOT: Zero elec. angle: 0.39
MOT: No current sense.
MOT: Ready.
is it working or not?
DC-supply is 11.9v(no chnage) and no ampere.
Is there any other key command to run motor?
because AS5147U has an ABI interface, I want to set up like the above, but not working.
So, I use above code. but now I do not connect nOCTW and nFAULT pin. Should I connect the pin nOCTW and nFAULT to UNO? IF so, where?
It seems like a good code. However in your monitoring output it looks like the sensor has not really well read the pole pairs number. That probably means that something is wrong.
Did you try using only the sensor?
You have one example in the library examples with which you can test if your sensor works properly.
Another question is: is your motor moving during the i it phase?
Of is it completely static?
Fault and octw pins are diagnostic pins that you are not required to read. You can lave them unconnected for now.
I tested sensor using example. <magnetic_sensor_spi_example>
In the serial monitor, I think the value is rad and velocity.
this is the result of parts.
| 3.93 |
5.57 |
| 3.94 |
5.13 |
| 3.94 |
4.73 |
| 3.95 |
3.91 |
| 3.95 |
3.52 |
| 3.95 |
2.36 |
| 3.96 |
1.56 |
| 3.96 |
0.78 |
| 3.96 |
0.00 |
| 3.96 |
-0.41 |
| 3.95 |
-1.51 |
| 3.95 |
-2.26 |
| 3.95 |
-3.03 |
| 3.95 |
-3.42 |
| 3.94 |
-1.49 |
| 3.94 |
-2.26 |
| 3.94 |
-1.50 |
| 3.94 |
-2.66 |
| 3.94 |
-2.25 |
| 3.93 |
-2.98 |
| 3.93 |
-3.41 |
| 3.92 |
-3.73 |
| 3.92 |
-3.40 |
| 3.92 |
-4.14 |
| 3.91 |
-4.10 |
| 3.91 |
-4.55 |
| 3.90 |
-5.24 |
| 3.90 |
-5.64 |
| 3.89 |
-6.42 |
| 3.88 |
-7.12 |
| 3.88 |
-7.93 |
| 3.87 |
-8.61 |
| 3.86 |
-10.19 |
| 3.84 |
-12.25 |
| 3.83 |
-13.29 |
| 3.81 |
-14.05 |
| 3.80 |
-15.80 |
| 3.78 |
-17.11 |
| 3.76 |
-16.63 |
| 3.74 |
-17.17 |
| 3.72 |
-17.11 |
| 3.70 |
-17.27 |
| 3.69 |
-17.66 |
| 3.67 |
-17.75 |
| 3.65 |
-19.17 |
| 3.62 |
-20.39 |
| 3.60 |
-21.74 |
| 3.58 |
-22.81 |
| 3.55 |
-23.52 |
| 3.53 |
-23.70 |
| 3.50 |
-24.24 |
| 3.47 |
-24.50 |
| 3.44 |
-26.67 |
| 3.42 |
-26.89 |
| 3.39 |
-27.90 |
| 3.36 |
-27.70 |
| 3.32 |
-29.47 |
| 3.29 |
-30.05 |
| 3.26 |
-31.12 |
| 3.22 |
-31.49 |
| 3.19 |
-30.05 |
| 3.16 |
-28.51 |
| 3.13 |
-30.42 |
| 3.09 |
-31.48 |
| 3.06 |
-32.20 |
| 3.02 |
-33.75 |
| 2.99 |
-32.56 |
| 2.95 |
-31.96 |
| 2.92 |
-32.91 |
| 2.88 |
-33.96 |
| 2.84 |
-35.42 |
| 2.81 |
-33.86 |
| 2.77 |
-33.15 |
| 2.74 |
-32.08 |
| 2.70 |
-33.16 |
| 2.67 |
-32.67 |
| 2.63 |
-31.25 |
| 2.60 |
-31.48 |
| 2.57 |
-31.84 |
| 2.53 |
-32.55 |
| 2.49 |
-33.27 |
| 2.46 |
-33.38 |
| 2.42 |
-33.73 |
| 2.38 |
-34.34 |
| 2.35 |
-34.93 |
| 2.31 |
-33.61 |
| 2.28 |
-32.90 |
| 2.24 |
-32.20 |
| 2.21 |
-32.19 |
| 2.17 |
-32.67 |
| 2.14 |
-32.08 |
| 2.10 |
-30.54 |
| 2.07 |
-28.73 |
| 2.04 |
-29.69 |
| 2.01 |
-31.48 |
motor is static.
