Mkay, using HDI ive kinda found room for a 64Mb QSPI NOR FLASH DRIVE. This could be used to boot a folder for config files.
It is sharing a stacked uVIA [Rosenbridge] with the MCU so it can only be done if the QSPI interface can be internally powered by 1.2v, without messing other pin power domain up. The IC can only tolerate op to 2v.
Under any circumstance the pins are there, so maybe a different routing for a different package.
Actually maybe the core voltage should be 1.8 or similar, and the analog_reference, shall remain 3.3v. ?
The STM32H747 has a low-voltage IO setup, that I have a hard time figuring out. When low voltage is set, does all low_voltage pin then work on core_voltage eg. 1.2 ? And the rest, those pins without _h specefication, on 3.3v ?
With a 133Mhz bandwidth, it can make some really dense samples for graphing ![]()
