I am new to foc control and simple foc library. I have been trying to get a closed position control example working with my set up. I am using the MKS ESP32 FOC controller and a AS5047 Encoder comunicating through SPI. I have a 5010 360kv bldc motor with 7pole pairs. I started with the maker Space open loop position control example and it worked fine besides some overheating. Now I am trying to conifgure the simple FOC position angle control(closed loop) example in their github but I am having lots of issues.
Firstly the encoder is returning values from 0 - 12ish in one full revolution. I think it should be in radians so 0-6.28 but I have no clue why it is off. There is also some noise of +/- 0.01 in the readings.
Secondly, when I test with this code or variations of this code the motor starts and moves one quarter rotation normaly but then starts jittering/shaking very fast. The serial input seems to do nothing when I tell it to go to a position. I have tried to tune the pid but with no luck. It seems like no mater what I do the motor just shakes very fast and uncontrolably. I also tried switching the motor wires with no avail. I am really lost and would really appreciate any help.
* Position/angle motion control example
* Steps:
* 1) Configure the motor and magnetic sensor
* 2) Run the code
* 3) Set the target angle (in radians) from serial terminal
MagneticSensorSPI sensor = MagneticSensorSPI(5, 14, 0x3FFF);
//MagneticSensorI2C sensor = MagneticSensorI2C(AS5600_I2C);
BLDCMotor motor = BLDCMotor(7); //According to pole pairs of the selected motor, modify the value of BLDCMotor() here
BLDCDriver3PWM driver = BLDCDriver3PWM(32,33,25,22);
// angle set point variable
float target_angle = 0;
// contoller configuration
motor.PID_velocity.P = 0.2f;
motor.PID_velocity.I = .1;//1
motor.voltage_limit = 1;
motor.LPF_velocity.Tf = 0.1f;
// angle P controller
motor.P_angle.P = 1;//20
motor.velocity_limit = 20;//20
// align sensor and start FOC
//sensor.update();
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
motor.move(target_angle);
// motor.monitor();
