Hi Guys, i am working with 36v 350W hub motor, B-G431-ESC and AB encoder. i connected the encoder with gear ratio of 1:5. i am wanted to use closed loop with Space Vector PWM for better efficiency. Two condition it got while motor initialize if motor cant move then click noise ESC not working anymore and other condition while tuning q_current and p_current parameters some time motor get vibrate while move and sudden jerk and B-G431 not working anymore. so anyone tried Pat92fr FOC2 code. what you guys think about that code. this is the code i am using
// Motor instance
BLDCMotor motor = BLDCMotor(15,0.7,40);
// encoder instance
Encoder encoder = Encoder(A_ENCODER_A, A_ENCODER_B, 3360);
unsigned long previousMillis = 0;
// channel A and B callbacks
void doIndex(){encoder.handleIndex();}
void doTarget(char* cmd)
command.motor(&motor, cmd);
previousMillis = millis();
// will store last time LED was updated
// constants won't change:
const long interval = 1000; // interval at which to blink (milliseconds
encoder.init();
motor.linkSensor(&encoder);
// aligning voltage [V]
// // index search velocity [rad/s]
motor.velocity_index_search = 1;
// motor.torque_controller = TorqueControlType::foc_current;
motor.motion_downsample = 0.1;
// contoller configuration
motor.PID_velocity.P = 0.6;
motor.PID_velocity.I = 0.8;
motor.PID_velocity.D = 0.00;
motor.PID_velocity.limit = 20.0;
motor.LPF_velocity.Tf = 0.01;
// angle P controller
// motor.P_angle.P = 0.8;
motor.velocity_limit = 20.0;
motor.current_limit = 8.0;
motor.voltage_limit = 20.0;
// Q axis
// PID parameters - default
motor.PID_current_q.P = 5; // 3 - Arduino UNO/MEGA
motor.PID_current_q.I = 0; // 300 - Arduino UNO/MEGA
motor.PID_current_q.D = 0;
motor.PID_current_q.limit = motor.voltage_limit;
motor.PID_current_q.output_ramp = 300; // 1000 - Arduino UNO/MEGA
// Low pass filtering - default
motor.LPF_current_q.Tf= 0.01; // 0.01 - Arduino UNO/MEGA
// D axis
motor.PID_current_d.P = 5; // 3 - Arduino UNO/MEGA
motor.PID_current_d.I = 0; // 300 - Arduino UNO/MEGA
motor.PID_current_d.D = 0;
motor.PID_current_d.limit = motor.voltage_limit;
motor.PID_current_d.output_ramp = 300; // 1000 - Arduino UNO/MEGA
motor.LPF_current_d.Tf= 0.01; // 0.01 - Arduino UNO/MEGA
motor.modulation_centered = 1.0;
// motor.useMonitoring(Serial);
currentSense.init();
// no need for aligning
// // align encoder and start FOC
command.verbose = VerboseMode::on_request;
// // add target command T
command.add('M', doTarget, "target angle");
// unsigned long currentMillis = millis();
// if (currentMillis - previousMillis >= interval) {
// // save the last time you blinked the LED
// // command.motor(&motor, "0.0");
// previousMillis = currentMillis;
Any suggestion please.
