How are the PWM signals generated by an Arduino Uno?
I have noticed the video on this link:
https://docs.simplefoc.com/arduino_simplefoc_shield_showcase
As far as I understand this video, a simple form of FOC is utilized by the controls from an Arduino Uno. I know the inner hardware of the Atmega 328P chip quite well, but I cannot figure out how this MPU is able to provide the PWM-signals for three phases (three half bridges). I think that the driver board receives all three PWM signals from the MPU. Are timer1 and timer2 synchronized to do this? I think that timer1 can only provide two PWM signals (not three as in many other MPUs).
I tried to look a bit into the libraries, but I did not find the low-level code that sets the timers.
How are the timers of this MPU utilized here to provide the PWM-signals?
Are the PWM-frequency fixed to be above 31.25 kHz (=16.000 kHz/512)?
3
Hi @Backflip ,
The low level driver code for 328P is here: Arduino-FOC/src/drivers/hardware_specific/atmega/atmega328_mcu.cpp at master · simplefoc/Arduino-FOC · GitHub
Yes, it syncs the timers and yes it uses 32kHz…
Yep, it uses multiple timers. The frequency is clamped to either 32kHz or 4kHz due to limited prescaler options. The code is in the drivers/hardware_specific folder:
Thank you for your replies. My guess about how the timers needed to be used was right then. There is not much flexibility in PWM-frequency with this MPU.
It is nice to know how to find the code used as well.
