Hoverboard main board with simpleFOC
I want to post another working example for the splitboard controller with the STM32F030 MCU.
The main parameters are 24V@50kHz, velocity mode with voltage-torque control.
This time I took the motor parameters from @OiD-W
I found that the PID values have a very small work-zone. A bit off and the motor runs crazy.
That’s why I added the accel2target ramp up in the main loop. It allows you to watch the motor going through the paces. Enough time to pull the plug when it gets funny
  10" hoverboard splitboard with STM32F030C8T6 MCU and hall sensors
#include <SimpleFOC.h>      //  has to be dev-branch for both libs
#include <SimpleFOCDrivers.h>
#include <encoders/smoothing/SmoothingSensor.h>
// Hall sensor instance
//  - hallA, hallB, hallC    - HallSensor A, B and C pins
//  - pp                     - pole pairs
HallSensor sensor = HallSensor(PA0, PF1, PC15, 15); //  blue, green, yellow, 15PP
// Interrupt routine intialisation
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
void doC(){sensor.handleC();}
BLDCMotor motor = BLDCMotor(15, 0.75, 19.0, 0.00119);  // 0.00036858); 0.75, 19, 0.00119
// BLDCDriver6PWM driver = BLDCDriver6PWM(UH, UL, VH, VL, WH, WL);
BLDCDriver6PWM driver = BLDCDriver6PWM(PA8,PB13,PA9,PB14,PA10,PB15);  //  blue, green, yellow gate driver pins
// instantiate the smoothing sensor, providing the real sensor as a constructor argument
SmoothingSensor smooth = SmoothingSensor(sensor, motor);
// instantiate the commander
float target_velocity = 0;
float accel2target = 0;
bool LED = true;
void SerialComm()
  switch(Serial2.read())
  case '?':
    Serial2.print("sensor_direction ");
    Serial2.print(motor.sensor_direction);
    Serial2.print(", zero_electric_angle ");
    Serial2.println(motor.zero_electric_angle);
    break;
  case 's': Serial2.print("shaft_velocity "); Serial2.println(motor.shaft_velocity); break;
  case 'a':
    Serial2.print("shaft_angle ");
    Serial2.print(motor.shaft_angle);
    Serial2.print(", electric_rotations ");
    Serial2.print(sensor.electric_rotations);
    Serial2.print(", electric_sector ");
    Serial2.println(sensor.electric_sector);
    break;
  case 'T': target_velocity = Serial2.parseFloat(); Serial2.print("Set ");
  case 't': Serial2.print("target "); Serial2.println(target_velocity);  break;
  case 'V': motor.voltage_limit = Serial2.parseFloat(); Serial2.print("Set ");
  case 'v': Serial2.print("motor.voltage_limit "); Serial2.println(motor.voltage_limit); break;
  case 'O': motor.PID_velocity.output_ramp = Serial2.parseFloat(); Serial2.print("Set ");
  case 'o': Serial2.print("motor.PID_velocity.output_ramp "); Serial2.println(motor.PID_velocity.output_ramp); break;
  case 'F': motor.LPF_velocity.Tf = Serial2.parseFloat(); Serial2.print("Set ");
  case 'f': Serial2.print("motor.LPF_velocity.Tf "); Serial2.println(motor.LPF_velocity.Tf); break;
  case 'P': motor.PID_velocity.P = Serial2.parseFloat(); Serial2.print("Set ");
  case 'p': Serial2.print("motor.PID_velocity.P "); Serial2.println(motor.PID_velocity.P); break;
  case 'I': motor.PID_velocity.I = Serial2.parseFloat(); Serial2.print("Set ");
  case 'i': Serial2.print("motor.PID_velocity.I "); Serial2.println(motor.PID_velocity.I); break;
  case 'D': motor.PID_velocity.D = Serial2.parseFloat(); Serial2.print("Set ");
  case 'd': Serial2.print("motor.PID_velocity.D "); Serial2.println(motor.PID_velocity.D); break;
  case 'W': motor.P_angle.P = Serial2.parseFloat(); Serial2.print("Set ");
  case 'w': Serial2.print("motor.P_angle.P "); Serial2.println(motor.P_angle.P); break;
// motor.zero_electric_angle
  case 'Z': motor.zero_electric_angle = Serial2.parseFloat(); Serial2.print("Set ");
  case 'z': Serial2.print("motor.zero_electric_angle "); Serial2.println(motor.zero_electric_angle); break;
  case ' ': target_velocity = 0; motor.voltage_limit = 0;
  pinMode(PB9,OUTPUT);  //  onboard LED for heartbeat signal
// monitoring port
  Serial2.begin(115200);
  while(!Serial2){};
  digitalWrite(PB9,LED);
  // initialise encoder hardware
  sensor.init();
  // hardware interrupt enable
  sensor.enableInterrupts(doA, doB, doC);
  // set SmoothingSensor phase correction for hall sensors
  //smooth.phase_correction = -_PI_6;
  motor.linkSensor(&smooth); // link the motor to the smoothing sensor
  // driver config
  // power supply voltage [V]
  driver.pwm_frequency = 50000;
  driver.voltage_power_supply =24;
  driver.voltage_limit = 24;
  driver.dead_zone = 0.1f;  // default 0.05f
  // link the motor and the driver
  // aligning voltage [V]
  motor.voltage_sensor_align = 6;
// set motion control loop to be used
  motor.torque_controller     = TorqueControlType::voltage;
  // motor.foc_modulation = FOCModulationType::Trapezoid_120;
  motor.foc_modulation        = FOCModulationType::SinePWM;
  // motor.controller     = MotionControlType::torque;    // set motion control loop to be used
  motor.controller     = MotionControlType::velocity;
  // controller configuration
  // default parameters in defaults.h
  // velocity low pass filtering time constant
  motor.PID_velocity.P  = 0.3f;
  motor.PID_velocity.I  = 0.3f;
  motor.LPF_velocity.Tf = 0.04f;  //  0.05
  // default voltage_power_supply
  motor.voltage_limit = 0.5f * driver.voltage_limit;
  motor.current_limit = 10;
  // jerk control using voltage voltage ramp
  // default value is 300 volts per sec  ~ 0.3V per millisecond
  motor.PID_velocity.output_ramp = 1000;
  // comment out if not needed
 motor.useMonitoring(Serial2);
  // initialize motor
  // align sensor and start FOC
  motor.zero_electric_angle  = 0.00f; // rad
  motor.sensor_direction = Direction::CCW; // CW or CCW
  _delay(1000);
  if (LED == true){
	  LED = false;}
	else {LED = true;}
  motor.loopFOC();
  //motor.monitor();
  motor.move(accel2target);
  // user communication
  if(Serial2.available() > 0){
    SerialComm();
  if (target_velocity != accel2target){
    if (target_velocity < accel2target) {accel2target -= 0.01f;}
    else {accel2target += 0.01f;}
  //Serial2.println(motor.shaft_velocity);
