Current Sensing using DRV8302
Hi @thewrongbutton -
Below is sample code to use the DRV8302 with a Nucelo F401RE board in 3 PWM mode, with full current sensing. I m using an AS5048A SPI angle sensor. Note the gains I used, along with the inversion of them in the code.
Note - some of the code is specific to my project, and also, the current PID gains are specific for a large AC servo motor. It works great!
// DRV8302 pins connections
#define INH_A PA8
#define INH_B PA9
#define INH_C PA10
#define EN_GATE PB7
#define M_PWM PB4
#define M_OC PB3
#define OC_ADJ PB6
#define OC_GAIN PB5
#define IOUTA A0
#define IOUTB A1
#define IOUTC A2
// Motor instance
BLDCDriver3PWM driver = BLDCDriver3PWM(INH_A, INH_B, INH_C, EN_GATE);
// DRV8302 board has 0.005Ohm shunt resistors and the gain of 12.22 V/V
LowsideCurrentSense cs = LowsideCurrentSense(0.005f, 12.22f, IOUTA, IOUTB, IOUTC);
// encoder instance
MagneticSensorSPI encoder = MagneticSensorSPI(AS5048_SPI, 14);
// commander interface
long time_ms = 0;
double iq_sp_A = 0;
double iq_max_A = 0.8;
double initial_position_rads = 0;
double position_rads = 0;
double delta_position_rads = 0;
float angle_rads = 0;
  //pinMode(PA5, OUTPUT);
  encoder.init();
  motor.linkSensor(&encoder);
  // DRV8302 specific code
  // M_OC  - enable overcurrent protection
  pinMode(M_OC,OUTPUT);
  digitalWrite(M_OC,LOW);
  // M_PWM  - enable 3pwm mode
  pinMode(M_PWM,OUTPUT);
  digitalWrite(M_PWM,HIGH);
  // OD_ADJ - set the maximum overcurrent limit possible
  pinMode(OC_ADJ,OUTPUT);
  digitalWrite(OC_ADJ,HIGH);
  pinMode(OC_GAIN,OUTPUT);
  digitalWrite(OC_GAIN,LOW);
  driver.pwm_frequency = 20000; // suggested under 18khz
  cs.linkDriver(&driver);
  // align voltage
  motor.voltage_sensor_align = 2.0;
  // control loop type and torque mode
  motor.motion_downsample = 1.0;
  // velocity loop PID
  motor.PID_velocity.P = 0.18;
  motor.PID_velocity.I = 7.0;
  motor.LPF_velocity.Tf = 0.007;
  // angle loop PID
  motor.P_angle.P = 25.0;
  motor.LPF_angle.Tf = 0.005;
  // current q loop PID
  motor.PID_current_q.P = 5.0;
  motor.PID_current_q.I = 500.0;
  motor.LPF_current_q.Tf = 0.005;
  // current d loop PID
  motor.PID_current_d.P = 5.0;
  motor.PID_current_d.I = 500.0;
  motor.LPF_current_d.Tf = 0.005;
  // Limits
  motor.velocity_limit = 20.0;
  motor.voltage_limit = 7.0;   // 12 Volt limit
  motor.current_limit = 2.0;    // 2 Amp current limit
  // monitoring port
  motor.monitor_variables = _MON_CURR_Q | _MON_CURR_D; // monitor the two currents d and q
  motor.monitor_downsample = 0;
  // initialise motor
  cs.init();
  cs.skip_align = true;
  // driver 8302 has inverted gains on all channels
  cs.gain_a *= -1;
  cs.gain_b *= -1;
  cs.gain_c *= -1;
  motor.linkCurrentSense(&cs);
  motor.initFOC(1.94, Direction::CW);
  motor.target = 0.0;
  // define the motor id
  Serial.println(F("Full control example: "));
  Serial.println(F("Run user commands to configure and the motor (find the full command list in docs.simplefoc.com) \n "));
  Serial.println(F("Initial motion control loop is voltage loop."));
  Serial.println(F("Initial target voltage 2V."));
  initial_position_rads = encoder.getAngle();
  time_ms = millis();
  float val = 12.0*sin(millis()/1000.0);
  motor.move(val);
  // monitoring the state variables
  // if (millis() - time_ms > 5){
  //   PhaseCurrent_s current = cs.getPhaseCurrents();
  //   Serial.print(current.a);
  //   Serial.print("\t");
  //   Serial.print(current.b);
  //   Serial.print(current.c);
  //   Serial.println("");
  //   time_ms = millis();
Thank you, this is very helpful! I was a bit silly and didn’t realise this board used low-side (I had assumed inline oops) and I’ll need to swap the Pico I’m currently using for an STM32 if I can find one lying around.
I believe @wrcman555 is correct in saying that you don’t need the reference voltage pin. You can just connect the IOUTx pins directly to your uC input pins and you should be fine (3.3V max so it’s safe)
From the Low-Side Current Sensing page in the docs:
current_sense.init();
Init function is responsible for
1 - configuring ADC for current sensing
2 - calibration - offset removal
So when you initialise current sensing it takes an ADC reading (there should be no current flowing through the phases at that time, thus the IOUTx pins will be sitting at the reference 1.65V) and knows to always offset all readings by that amount.
Hi @wrcman555 i just want to make sure, based on the image of each phase current that you send, so the current is AC (Alternating Current) right?
@zulfiar-am yep, they’re sinusoidal ac waveforms, whose frequency map to the motor rpm. So if the shaft is stopped, the values are all steady at some value.
