Hello for my college project i am trying to setup sensorless foc.
Board: Teensy 4.0 Driver: AliExpress DRV8302 (0.005Ω shunt, 12.22 V/V gain, low-side current sense) Motor: 1000KV BLDC drone motor, 7 pole pairs, ~55mΩ phase resistance, ~1mH inductance Library: SimpleFOC + SimpleFOCDrivers, MXLEMMING sensorless observer
I started by running the motor in open-loop voltage mode to characterize it, and then tried switching to foc_current torque control with the MXLEMMING observer.
Motor characterization results:
Phase resistance: 0.055 Ω (phase-phase 0.11Ω)
Phase inductance: 0.001 H (1mH Q-axis , 1.1mH D axis)
KV: 1000 rpm/V
Pole pairs: 7
Current sense ADC offsets (Teensy 3.3V ADC, 12-bit):
Offset A: ~1.670 V
Offset B: ~1.668 V
Offset C: ~1.659 V (These look correct — midpoint of 3.3V supply)
For the current sensing on DRV8302 i got help from (with a litle twick of adding external refference the teensy 3.3V to the DRV8302 current sense)
The Problem
With the code below, Iq slowly drifts toward the target (0) but never locks on, and Volt_Q swings wildly between ±1500V equivalent — clearly the integrator is winding up without any effective clamping.
Monitor output (_MON_CURR_Q | _MON_VOLT_Q):
0.0000 -0.0264
-0.9000 -2200.0
-1.0000 3500.0
#include <SimpleFOCDrivers.h>
#include "encoders/MXLEMMING_observer/MXLEMMINGObserverSensor.h"
#define INH_A 6
#define INH_B 5
#define INH_C 4
#define EN_GATE 7
#define M_PWM 12
#define M_OC 11
#define OC_ADJ 9
#define GAIN 10
#define DC_CAL 8
#define PIN_NFAULT 15
#define IOUTA 17
#define IOUTB 18
#define IOUTC 19
BLDCMotor motor = BLDCMotor(7, 0.055f, 1000.0f, 0.001f);
BLDCDriver3PWM driver = BLDCDriver3PWM(INH_A, INH_B, INH_C, EN_GATE);
//shunt of drv8302 0.005 Ohms and the gain is 12.22 V/V
LowsideCurrentSense cs = LowsideCurrentSense(0.005f, 12.22f, IOUTA, IOUTB, IOUTC);
MXLEMMINGObserverSensor observer = MXLEMMINGObserverSensor(motor);
volatile bool flag_nfault = false;
void isr_nfault() { flag_nfault = true; }
Serial.begin(460800);
delay(300);
// DRV8302 config
pinMode(M_OC, OUTPUT); digitalWrite(M_OC, LOW);
pinMode(M_PWM, OUTPUT); digitalWrite(M_PWM, HIGH);
pinMode(OC_ADJ,OUTPUT); digitalWrite(OC_ADJ,HIGH);
pinMode(GAIN, OUTPUT); digitalWrite(GAIN, LOW);
pinMode(DC_CAL,OUTPUT); digitalWrite(DC_CAL,LOW);
pinMode(PIN_NFAULT, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(PIN_NFAULT), isr_nfault, FALLING);
driver.voltage_power_supply = 12.0f;
driver.pwm_frequency = 20000;
cs.linkDriver(&driver);
cs.init();
cs.gain_a *= -1; //inv gains in DRV8302
cs.gain_b *= -1;
cs.gain_c *= -1;
cs.skip_align = true;
motor.linkCurrentSense(&cs);
motor.linkSensor(&observer);
motor.voltage_limit = 2.0f;
motor.current_limit = 1.0f;
motor.PID_current_q.P = 0.05f;
motor.PID_current_q.I = 5.0f;
motor.PID_current_q.limit = 2.0f;
motor.PID_current_q.output_ramp = 500.0f;
motor.PID_current_d.P = 0.05f;
motor.PID_current_d.I = 5.0f;
motor.PID_current_d.limit = 2.0f;
motor.PID_current_d.output_ramp = 500.0f;
motor.LPF_current_q.Tf = 0.01f;
motor.LPF_current_d.Tf = 0.01f;
motor.sensor_direction = Direction::CW;
motor.zero_electric_angle = 0.0f;
motor.monitor_downsample = 100;
motor.monitor_variables = _MON_CURR_Q | _MON_VOLT_Q;
command.add('T', doTarget, "target Iq [A]");
command.add('M', doMotor, "motor config");
if (flag_nfault) { flag_nfault = false; Serial.println("DRV: nFAULT!"); }
I am not very familiar with pid tuning and the library. I would gladly appreciate your help .
Thank you !!!
