Hello everyone,
I have been trying to implement a closed angle control loop using a stepper motor but have run into some unexpected behavior. My current setup includes an Arduino Mega 2560, L298N motor driver, a 0.9 deg/step bipolar stepper motor and an AMT103-V capacitive encoder. I have the motor driver powered at 12v from a variable benchtop power supply. I have set my encoder for 512 ppr.
I have an application that requires a positional control loop and backdrivability. When attempting to run this example from the SimpleFOCDocs I have encountered erratic jittering when using MotionControlType::angle and no motion or holding torque when attempting to use MotionControlType::torque. When calculating the pole pair number for my motor, I used the following equation: pole_pair = (steps/rotation) / 4; In my case, (400 steps/rev) / 4 = 100 PP, however when I set StepperMotor motor = StepperMotor(100); I get a failed PP check when running the code shown below, and a changing estimation that is always higher than the calculated value.
Assuming I had miscalculated the PP number, I tried using find_pole_pairs_number under Simple FOC>utils>calibration>find_pole_pair_number>encoder>find_pole_pairs_number. This yields something like this:
When using StepperMotor motor = StepperMotor(102); (or whatever the estimated PP) I still get the erratic behavior, as seen in the clip below:
https://youtu.be/bVqnWa4HgVQ
The motor heats up, and when the rotor is moved it begins to jump erratically until it settles again, usually in a random angle. Additionally, the index search I believe should be one full rotation, but as you can see in the clip is far less than that.
I have tried running the same setup with MotionControlType::angle_openloop and MotionControlType::velocity_openloop, using the same setup and both worked as expected.
I have also tried:
- Running the setup with/without index pin on encoder
- Running the example using a Nucleo-64 board (as in the example)
- Changing encoder resolution (tried 2048 PPR and 512 PPR)
- Changing the PID gains
I believe that I am misunderstanding something about the functionality seen in the code I am running below. If anyone has any ideas on why this is happening, let me know!
// Stepper motor instance
// Stepper driver instance
StepperDriver4PWM driver = StepperDriver4PWM(5, 6, 9, 10);
// encoder instance
Encoder encoder = Encoder(2, 3, 512, 21);
// channel A and B callbacks
void doIndex(){encoder.handleIndex();}
// commander interface
encoder.init();
encoder.enableInterrupts(doA, doB, doIndex);
motor.linkSensor(&encoder);
// choose FOC modulation
motor.PID_velocity.P = 0.2;
motor.PID_velocity.I = 10;
motor.voltage_limit = 12;
motor.LPF_velocity.Tf = 0.01;
// angle loop controller
motor.P_angle.P = 20;
// angle loop velocity limit
motor.velocity_limit = 50;
// monitoring port
// initialise motor
motor.target = 1;
// define the motor id
float target_angle = 1;
long timestamp_us = _micros();
// real time monitoring calls
//motor.monitor();
//command.run();
Thank you!
Michael L.
