AS5048A with Mks dual foc v3.3 and GM6208-150T Gimbal Motor
Having satisfactorily gotten my GM6208 to work in Open loop mode: Open loop velocity control not working at low velocity
I want to add the AS0548A I have but I am confused about how to connect it.
From what I have read I should be using SPI rather than PWM, due to better performance and I believe I should be using this library: Arduino-FOC-drivers/src/encoders/as5048a at master · simplefoc/Arduino-FOC-drivers · GitHub
I have an Mks dual foc v3.3 with the included ESP32 that is soldered to the driver board using the supplied risers.
Makerbase have a closed loop velocity example: MKS-DUALFOC/Test Code/4_close_loop_velocity_example/4_close_loop_velocity_example.ino at main · makerbase-motor/MKS-DUALFOC · GitHub in which it appears to me they are using pins 19 & 18 and 23 & 5 for each motor’s SDA and SLC:|
MagneticSensorI2C sensor1 = MagneticSensorI2C(AS5600_I2C);
TwoWire I2Cone = TwoWire(0);
TwoWire I2Ctwo = TwoWire(1);
  I2Cone.begin(19, 18, 400000);
  I2Ctwo.begin(23, 5, 400000);
  sensor.init(&I2Cone);
  sensor1.init(&I2Ctwo);
  //Connect the motor object with the sensor object
  motor1.linkSensor(&sensor1);
Great - but what I can’t figure out is which connections from the AS5048A are SDA and SLC.
I guess if I actually understood what SDA and SLC are I might be able to make an educated guess, but I would prefer to understand this.
I assume I would need to connect ground, and 5V (can I use 3.3V?) but which of nCS, CLK, MOSI, and MISO equate to SDA and SLC?
Sorry - my ignorance is once again showing.
9
Hi there!
I have also recently got a MKS DualFOC V3.3 for a self balancing robot I’m working on and have had it working with AS5048A encoders over SPI but I am not using the Lolin32 Lite board and have instead been using an ESP32-S3 Devboard currently but I have been designing a PCB as a drop in replacement for the Lolin board.
The board is currently being shipped to me so I haven’t been able to test as of yet but it breaks out 4 SPI connections as well as whatever GPIO are spare to the pins on the DualFOC.
After I have been able to test, I can share the design files if you like.
EDIT: Why are you powering the ESP32 whilst also connecting it to the DualFOC? The DualFOC supplies 3.3V directly to the ESP32 3.3V pin using the pin sockets so you’re probably having brownout or voltage issues causing your current sense errors.
Nice project—do you have the board up and running? Which gyro sensor did you use?
// SPI Magnetic sensor instance (AS5047U example)
// MISO 12
// MOSI 9
// SCK 14
MagneticSensorSPI sensor = MagneticSensorSPI(AS5147_SPI, 5);  //15  for ESP32:CS=5,SCK=18,MISO=19,MOSI=23
// I2C Magnetic sensor instance (AS5600 example)
// make sure to use the pull-ups!!
// SDA 21
// SCL 22
// magnetic sensor instance - I2C
// MagneticSensorI2C sensor = MagneticSensorI2C(AS5600_I2C);
// Analog output Magnetic sensor instance (AS5600)
// Motor instance
BLDCMotor motor = BLDCMotor(7);   //11
BLDCDriver3PWM driver = BLDCDriver3PWM(25, 26, 27, 33);  //(25, 26, 27, 7);
// angle set point variable
float target_angle = 0;
void doTarget(char\* cmd) { command.scalar(&target_angle, cmd); }
// power supply voltage \[V\]
motor.controller = MotionControlType::velocity;   //torque,velocity,angle
// contoller configuration
motor.PID_velocity.P = 0.2;   //0.2
motor.PID_velocity.I = 0.5;   //20
motor.voltage_limit = 6;          //12/1.732=6.928
motor.voltage_sensor_align = 1;   //
motor.LPF_velocity.Tf = 0.05;     //
// angle P controller
motor.P_angle.P = 20;
motor.velocity_limit = 20;
// align sensor and start FOC
command.add(‘T’, doTarget, (char \*)“target angle”);
\_delay(1000);
//float target_angle = 0;
// Arduino UNO loop  \~1kHz
// Bluepill loop \~10kHz
motor.move(target_angle);
// motor.monitor();
Yes, AS5048A will work with 3.3V.
Looking at an ESP32 pinout, it looks like 23 is MOSI, 19 is MISO, 18 is SCK, and 5 is CS. So since the example code is using those pins for I2C, that likely means the four pins labeled SDA and SCL on the Dual FOC are connected to those ESP32 pins, and it’s just a matter of sorting out which is which with a multimeter.
The real question is how they’re able to use those pins for I2C :slight_smile: The ESP32 pinout looks like it only has one I2C interface on pins 21 and 22.
Thanks for that, with your suggestion I have determined (I think) which pins on the DualFOC header pins go to which pins on the ESP32.
I wired up a harness for it:
And it gets plugged in here:
I have continuity between the soldered pads on the AS5048A and the GPIO pins on the ESP32 for all 6 lines using this as a reference: ESP32 Pinout Reference - Last Minute Engineers
According to this: Magnetic sensor SPI | Arduino-FOC I believe I should:
  1. create an instance of the MagneticSensorSPI class. I used GPIO5 for chip_select, I can confirm continuity between the AS5048A nCS solder pad and GPIO5 on the ESP32:
MagneticSensorSPI sensor = MagneticSensorSPI(5, 14, 0x3FFF);
  1. Initialize and link the sensor:
// init magnetic sensor hardware
  1. Initialize and link the driver:
// driver
  driver.init()
  1. Initialize the motor:
// init motor hardware
  1. call loopFOC() and move() in the main loop:
void loop(){
So I loaded the closed loop example full_control_serial from the Arduino examples, modified for my motor and sensor:
 * Comprehensive BLDC motor control example using magnetic sensor
 * Using serial terminal user can send motor commands and configure the motor and FOC in real-time:
 * - configure PID controller constants
 * - change motion control loops
 * - monitor motor variabels
 * - set target values
 * - check all the configuration values
 * See more info in docs.simplefoc.com/commander_interface
BLDCDriver3PWM driver = BLDCDriver3PWM(32,33,25,22);
// commander interface
  // link driver
  motor.PID_velocity.P = 0.2f;
  motor.PID_velocity.I = 20;
  motor.voltage_limit = 12;
  // angle loop controller
  // angle loop velocity limit
  motor.velocity_limit = 50;
  // initialise motor
  motor.target = 2;
  // define the motor id
  command.add('A', onMotor, "motor");
The driver board has a 5V out which I pass to the ESP32 so it is powered when no serial cable is connected to the PC:
If I leave the power connection from the Driver board to the ESP32 I am getting this in the serial monitor on a reset:
rst:0x1 (POWERON_RESET),boot:0x1b (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:4916
load:0x40078000,len:16436
load:0x40080400,len:4
ho 8 tail 4 room 4
load:0x40080404,len:3524
entry 0x400805b8
ESP32-DRV: Configuring 3PWM in group: 0 on timer: 0
ESP32-DRV: Configuring 2 operators.
ESP32-DRV: Configuring 3 comparators.
ESP32-DRV: Configuring 3 generators.
ESP32-DRV: Configuring center-aligned pwm.
ESP32-DRV: Enabling timer: 0
ESP32-DRV: MCPWM configured!
MOT: Monitor enabled!
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: Init FOC failed.
Motor commands sketch | Initial motion control > torque/voltage : target 20V.
If I disconnect the power leaving only the USB serial 5V I get this on reset:
ho 8 tail 4 room 4
entry 0x400805b8
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: sensor_direction==CW
MOT: PP check: fail - estimated pp: 0.97
MOT: Zero elec. angle: 1.18
MOT: No current sense.
MOT: Ready.
What is:
I had expected after this to be able to enter commander commands at the serial console and be able to control the motor but I cannot.
I appear to be flailing…
Any suggestions? I am really struggling to get this motor to run in a closed loop.
Try MagneticSensorSPI sensor(AS5048_SPI, 5);
I haven’t used any SPI sensors myself, but I assume if there’s a special configuration for it then it probably needs some non-default settings.
EDIT: Or better yet, that even more specialized class in the drivers repository that you linked in the original post.
Thanks both of you guys.
@dekutree64 thanks for that. No change unfortunately.
@claw_ntl
Because I am a bit ignorant and trying to figuring this out I guess. I couldn’t find much documentation that I could really understand, some of it going over my head.
This stuff is relatively new to me, and I have a lot to learn.
Which wires from the AS5048A did you use may I ask? Do you have any suggestions for what I am missing?
I would definitely be very interested in hearing how that board goes too.
Some documentation, schematics and examples can be found here: https://github.com/makerbase-motor/MKS-DUALFOC
I am using the MISO, MOSI, CLK and CS pins on the AS5048A for 4 Wire SPI communication (also note the AS5048A does not support I2C). I recommend using the SimpleFOC Drivers library for the AS5048A (https://github.com/simplefoc/Arduino-FOC-drivers/tree/master/src/encoders/as5048a).You will probably need to initialise the SPI bus for it to work. See the code I have written below as reference but just check the pin definitions:
#include <SPI.h>
// SimpleFOC
#include <SimpleFOCDrivers.h>
#include "encoders/as5048a/MagneticSensorAS5048A.h"
// Change these to suit the pins you use
#define HSPI_MOSI     23
#define HSPI_MISO     19
#define HSPI_SCK      18
#define CS_ENC_A      5
#define CS_ENC_B      -1
// Setup a pointer for the SPI class
SPIClass *hspi = NULL;
// SPI Clock Speed - AS5048A support 10 MHz maximum
static const uint32_t AS5048A_spiClk = 1000000UL;  // 1 MHz
// Create sensor instances
MagneticSensorAS5048A sensorA(CS_ENC_A, false, SPISettings(AS5048A_spiClk, MSBFIRST, SPI_MODE1));
MagneticSensorAS5048A sensorB(CS_ENC_B, false, SPISettings(AS5048A_spiClk, MSBFIRST, SPI_MODE1));
	// Create hspi instance
	hspi = new SPIClass(HSPI); // Original ESP32 has HSPI and VSPI available for use
	hspi->begin(HSPI_SCK, HSPI_MISO, HSPI_MOSI); // Assign the pins
	// Assign the SPI bus to the the sensors
	sensorA.init(hspi);
	sensorB.init(hspi);
The bare PCB should be delivered this week so should be able to test soon.
@IB_Mr.0_o Hi,
Could you be able to share your setup with me for open loop and closed loop both, I have this motor: iFlight iPower Gimbal Motor GM3506 with AS5048A encoder, iFlight iPower Gimbal Motor GM3506 UAV pod motor / Turntable Airborne Lidar Pod motor with AS5048A Encoder /Encode Aluminum Case - AliExpress 44
and MKS Dual FOC V3.2 Plus Driver, I even tried there example code for open loop and closed loop from their Github repository: MKS-DUALFOC/Test Code/2_open_loop_position_example at main · makerbase-motor/MKS-DUALFOC · GitHub
Changed the required parameters in the code like the pole pairs to 11, and the voltage limit for motors, but in open loop when I give the power to esp32 and to the driver it just gives a jerk to the gimbal motor I tried to change the voltage limits of both the driver and the motor, tried to change the maximum speed but the motor doesn’t move even an inch.
In closed loop too, I suppose I have connected the encoder properly with correct connections with the driver and verified the continuity between the connections, but it fails to run. Please, I need your kind help I am struggling with this setup for 5 days and I don’t seem to find what is I am missing in this setup.
Also, do I have to do something specific I mean I am getting confused after this that this requires a firmware, so do I have to upload any specific code before to run it or is the example codes serves the purpose.?
Thank You
Sorry for taking so long to reply.
I am not the one to help I am afraid. I have spectacularly failed to drive this motor in closed loop.
