It most certainly makes sense when designing for a geared setup. Multiplying the gear-ratio means multiplying the torque while maintaining target top speed if utilizing this phenomenon. A simple lookup table with velocity vs. angle offset should do the trick. I wonder if the extra torque will make up for the lost torque? @Owen_Williams
