I have the following hardware:
gimbal motor with a phase resistance around 3 ohm and KV around 100 rpm/v
B-G431B-ESC1 discovery kit
AMT103-v position sensor.
I’m trying to drive this motor (unloaded) at max speed, but I’m seeing strange behavior. If I slightly over-estimate motor.zero_electrical_angle, the velocity in the positive direction increases but the velocity in the negative direction decreases. Specifically, at the initFOC() calibrated zero_electrical_angle and 7 volts, the speed in either direction is around 82 rad/s. With zero_electrical_angle + 0.5, the speed in one direction is 59 rad/s and 97 rad/s in the other direction.
What causes this behavior?
If the motor turns faster at the same voltage_limit, does that mean the motor is being driven more efficiently? Or is it more efficient to increase motor.voltage_limit to obtain higher speeds?
Test code:
void test_electrical_angle() {
// not shown: motor / encoder initialization
const float desired_voltage = 7;
const float test_duration = 3; // seconds
const float original_angle = motor.zero_electric_angle;
Serial.printf("starting electrial angle measurements...\r\n");
for (float angle_offset = -1.0; angle_offset <= 1; angle_offset += 0.1) {
motor.zero_electric_angle = original_angle - angle_offset;
int iters = 0;
float end_ts = _micros() + test_duration * 1e6;
float max_speed = 0;
LowPassFilter lpf(.2);
while (_micros() <= end_ts) {
iters++;
motor.move(desired_voltage);
max_speed = max(max_speed, lpf(abs(encoder.getVelocity())));
float min_speed = 0;
lpf = LowPassFilter(.2);
motor.move(-desired_voltage);
min_speed = max(min_speed, lpf(abs(encoder.getVelocity())));
Serial.printf("zero electrical angle: %6.3f %+4.2f, +velocity: %7.3f -velocity: %7.3f. %7.1f foc iterations/s\r\n", original_angle, angle_offset, max_speed, min_speed, float(iters / test_duration));
motor.move(0);
delay(1000 * 9999);
output:
zero electrical angle: 0.930 -1.00, +velocity: 2.325 -velocity: 102.791. 10957.7 foc iterations/s
zero electrical angle: 0.930 -0.90, +velocity: 37.211 -velocity: 102.600. 7657.3 foc iterations/s
zero electrical angle: 0.930 -0.80, +velocity: 45.145 -velocity: 102.112. 7296.0 foc iterations/s
zero electrical angle: 0.930 -0.70, +velocity: 50.514 -velocity: 101.180. 6944.7 foc iterations/s
zero electrical angle: 0.930 -0.60, +velocity: 55.401 -velocity: 99.664. 6485.0 foc iterations/s
zero electrical angle: 0.930 -0.50, +velocity: 59.233 -velocity: 97.343. 6052.0 foc iterations/s
zero electrical angle: 0.930 -0.40, +velocity: 64.450 -velocity: 93.969. 5732.3 foc iterations/s
zero electrical angle: 0.930 -0.30, +velocity: 68.398 -velocity: 90.029. 5379.0 foc iterations/s
zero electrical angle: 0.930 -0.20, +velocity: 72.916 -velocity: 86.935. 5060.0 foc iterations/s
zero electrical angle: 0.930 -0.10, +velocity: 77.711 -velocity: 85.847. 4812.7 foc iterations/s
zero electrical angle: 0.930 +0.00, +velocity: 82.050 -velocity: 82.579. 4666.7 foc iterations/s
zero electrical angle: 0.930 +0.10, +velocity: 85.652 -velocity: 78.561. 4513.3 foc iterations/s
zero electrical angle: 0.930 +0.20, +velocity: 86.619 -velocity: 73.090. 4377.3 foc iterations/s
zero electrical angle: 0.930 +0.30, +velocity: 89.765 -velocity: 69.055. 4200.7 foc iterations/s
zero electrical angle: 0.930 +0.40, +velocity: 93.383 -velocity: 64.732. 4049.3 foc iterations/s
zero electrical angle: 0.930 +0.50, +velocity: 96.874 -velocity: 59.851. 3941.0 foc iterations/s
zero electrical angle: 0.930 +0.60, +velocity: 99.382 -velocity: 55.736. 3837.3 foc iterations/s
zero electrical angle: 0.930 +0.70, +velocity: 100.954 -velocity: 50.830. 3739.7 foc iterations/s
zero electrical angle: 0.930 +0.80, +velocity: 101.886 -velocity: 45.949. 3670.3 foc iterations/s
zero electrical angle: 0.930 +0.90, +velocity: 102.209 -velocity: 38.086. 3646.7 foc iterations/s
Similar results are obtained with other FOCModulationType.
