In recent months and even years now, I’ve had a great expectations from the drv8316. As it has all the good stuff
Integrated triple half bridge
integrated low-side current sensing
a good LDO
relatively respectable current limit 5A/8a peak
small package
Recently I’ve had a chance to work with a board with this chip intended to be used with 24V power supply. With this board there was a problem of jerky open loop control of the motor at 25kHz pwm frequency.
Looking at the signals with a scope, I was surprised to see a pretty long rise time of the PWM signal. I was able to measure it at around 1.5us. That is actually very long, I was expecting it to be an order or magnitude smaller from such a recent driver. Going through the datasheet, it seems like this slew rate is actually expected. (datasheet page 63 )
Did some of you guys have similar observations?
Did you see some other limitations of this chip?
Hey, this seems long to me also, but I’ll try to look at one of my DRV8316 drivers under the scope this WE and let you know the results.
I can’t say I remember observing a problem though. The slew rate can be set in a configuration register, and you can set it up to 200V/us, which should give you around 150ns rise time on 24V.
The default setting is 25V/us so it would be around 1us (20-80%) according to the datasheet… that may be the 1.5us you’re seeing if you were looking at 0-100%?
Setting the slew rate to the maximal value definitely helps a lot. Currents became almost sinusoidal and the torque control now works fine.
Here is the difference using a scope. I’ve changed the slew rate after a few seconds. Two phases out of three are shown in the video.
I am still amazed that there is such a big difference between the slew rates and that the longer one is set by default. With the lower slew rate the PWM is not even center aligned any more.
I was wondering if anyothe have similar issues?
Keep in mind that this issue can be caused by the propriatery board that I’m using too.
Interesting data! What do you think is good minimum rise time for 25KHz? I can see why TI gives different slew rate options, as slower can be better for EMI. I’m driving a 36V motor with DRV8376 which allows a minimum of slew rate of 50V/µs (20% - 80%). At this slew rate I’ve noticed slightly more noise/vibrations coming from the motor compared to the highest (1100V/µs).
Looking at the datasheet, the DRV8316’s dead time is also pretty long. 500-750ns with the fastest 200V/s slew rate setting, up to 1800-3400ns with 25V/s. I’ve only tested with 400ns on different hardware, but this method of deadtime compensation works very well to correct the sine wave distortion, and would likely work for compensating slew rate as well PWM Deadtime compensation - #39 by dekutree64
