I’m using 3 methods to read from a MT6835 magnetic encoder:
- SPI
- AB with interrupt (using the `Encoder` class)
- AB with hardware counter (using the `ESP32HWEncoder` class)
The three methods give the same angle measurements. However, when it comes to velocity computation, the Encoder class gives aberrant values:
SPI - Ang: -0.364593 Vel: 0.0203945
AB (int) - Ang: 0.365375 Vel: -0.180679
AB (hw) - Ang: 0.365375 Vel: -0.0204003
SPI - Ang: -0.344439 Vel: 0.0201351
AB (int) - Ang: 0.345242 Vel: -2.26831
AB (hw) - Ang: 0.345242 Vel: -0.0201141
SPI - Ang: -0.132929 Vel: 0.211293
AB (int) - Ang: 0.133744 Vel: -2.26831
AB (hw) - Ang: 0.133744 Vel: -0.21128
SPI - Ang: -0.361214 Vel: -0.228054
AB (int) - Ang: 0.362019 Vel: 0
AB (hw) - Ang: 0.362019 Vel: 0.228045
SPI - Ang: -0.361214 Vel: 0
I tried to reduce the CPR, or to slow down the loop, but the issue persists.
Here is my code:
Read values from MT6835 encoder using SPI, AB/interrupt and AB_hardware counter
See:
https://github.com/simplefoc/Arduino-FOC-drivers/tree/master/src/encoders/mt6835
https://github.com/simplefoc/Arduino-FOC-drivers/tree/master/src/encoders/esp32hwencoder
#include "SimpleFOC.h"
#include "encoders/esp32hwencoder/ESP32HWEncoder.h"
#include "encoders/mt6835/MagneticSensorMT6835.h"
// Encoder SPI communication
// SPI pins
#define PIN_SCK 18
#define PIN_MISO 17
#define PIN_MOSI 16
#define PIN_CS 40
SPIClass spi(HSPI);
MagneticSensorMT6835 sensor(PIN_CS);
// Encoder AB communication (through interrupt)
#define PIN_ENC_Y_A 44
#define PIN_ENC_Y_B 48
constexpr uint16_t AB_RESOLUTION = 16384; // Pulse-per-revolution, max 16384
Encoder encoder(PIN_ENC_Y_A, PIN_ENC_Y_B, AB_RESOLUTION);
void doA() { encoder.handleA(); }
void doB() { encoder.handleB(); }
// Encoder AB communication (using esp32 harware counter)
ESP32HWEncoder encoder2(PIN_ENC_Y_A, PIN_ENC_Y_B, AB_RESOLUTION);
delay(4000);
printf("\n\n--- MT6835 Test ---\n");
// Initialize SPI
if (!spi.begin(PIN_SCK, PIN_MISO, PIN_MOSI)) {
printf("SPI bus not initialized, exiting...\n");
while (1);
// Initialize the SPI sensor
sensor.init(&spi);
// Check default settings to see if the sensor is initialized correctly
if (sensor.getBandwidth() != 5 || sensor.getHysteresis() != 7) {
printf("MT6835 not initialized correctly, exiting...\n");
while (1);
// Reset the SPI sensor to zero in order to match the AB values
const bool res = sensor.setZeroFromCurrentPosition();
assert(res);
// Use SPI to set the AB resolution
sensor.setABZResolution(AB_RESOLUTION - 1);
assert(sensor.getABZResolution() == AB_RESOLUTION - 1);
// AB setup (interrupt)
encoder.quadrature = Quadrature::ON;
encoder.pullup = Pullup::USE_INTERN;
encoder.init();
// AB setup (harware counter)
encoder2.pullup = Pullup::USE_INTERN;
encoder2.init();
sensor.update();
encoder.update();
encoder2.update();
static auto ts = millis();
const auto now = millis();
if (now - ts > 1000) {
ts = now;
printf("---------\n");
printf("SPI - Ang: %g Vel: %g\n", sensor.getAngle(),
sensor.getVelocity());
printf("AB (int) - Ang: %g Vel: %g\n", encoder.getAngle(),
encoder.getVelocity());
printf("AB (hw) - Ang: %g Vel: %g\n", encoder2.getAngle(),
encoder2.getVelocity());
(I know encoder and encoder2somehow walk all over each other, but removing one or the other gives the same results)
Am I missing something?
