Hello all,
I have a BLDC motor without a decoder sensor and I’m testing the code example “Velocity open-loop control” to try to make it work with ESP32 in combination with DRV8302. It works for some seconds and then stops working.
Do you have any idea what is happening?
Thanks in advance for your help.
This is the code I’m using:
// DRV8302 pins connections
// don’t forget to connect the common ground pin
#define INH_A 21
#define INH_B 22
#define INH_C 23
#define INL_A 13
#define INL_B 12
#define INL_C 14
#define EN_GATE 19
#define M_PWM 36
#define M_OC 39
#define OC_ADJ
// BLDCMotor( pp number , phase resistance, KV rating)
BLDCMotor motor = BLDCMotor(11 , 5, 1000);
BLDCDriver6PWM driver = BLDCDriver6PWM(INH_A, INL_A, INH_B,INL_B, INH_C, INL_C, EN_GATE);
void doLimitCurrent(char* cmd) { command.scalar(&motor.current_limit, cmd); }
// limiting motor current (provided resistance)
motor.current_limit = 3;
// open loop control config
// init motor hardware
command.add(‘C’, doLimitCurrent, “current limit”);
Serial.println(“Motor ready!”);
Serial.println(“Set target velocity [rad/s]”);
// using motor.current_limit and motor.velocity_limit
