We have tried both HSPI and VSPI ports on the ESP 32, with it currently being wired to the VSPI ports and are running the demo code on GitHub:
// MagneticSensorSPI(MagneticSensorSPIConfig_s config, int cs)
// config - SPI config
// cs - SPI chip select pin
MagneticSensorSPI sensor = MagneticSensorSPI(AS5048_SPI, 10);
// alternative constructor (chipselsect, bit_resolution, angle_read_register, )
// MagneticSensorSPI sensor = MagneticSensorSPI(5, 14, 0x3FFF);
// monitoring port
// this function reads the sensor hardware and
// has to be called before getAngle nad getVelocity
sensor.update();
Serial.print("\t");
I set up the Arduino IDE accordingly, installing the Simple FOC library, adding the GitHub link to the additional board manager URL, setting the board to esp32-wroom-da (I assume this is right, the board is esp-wroom-32u).
When I move the gm3506 motor, the serial plotter’s output is crazy, fluctuating constantly between positive and negative values, and then settling on an arbitrary value.
Any ideas on what the issue could be?
