Hi guys! I am using the DRV8313 driver to test a cutomized pcb. The motor I want to drive is exactly: Amazon.com: DC 3.7V-11.1V 7.4V 4300KV Mini 1104 3-phase Brushless Motor Micro Outer Rotor BLDC for Quadcopter Fixed Wing : Toys & Games
The board has a STM32L433RC and I am using STMDuino to test the open loop velocity code (the schematics are at the end of this message). What I am getting is noises comming out from the motor. The code I am using is from the open loop examples, I don’t know what is going on, I read in one forum that if I change the PID parameters it can work. Furthermore, I used a logic analyzer to see if there are any ouput on the PWM pins and there are, but no ouput on the mosfet lines, I also checked the DRV_EN pin in the pcb and it is pulled high.
#define DRV_EN PB12
BLDCMotor motor = BLDCMotor(12); // WE NEED TO FND THIS ACCORDING TO OUR BLDC MOTOR
BLDCDriver3PWM driver = BLDCDriver3PWM(PA10, PB11, PB10, DRV_EN);
//target variable
float target_velocity = 100;
//driver.voltage_limit = 6;
if(!driver.init()){
return;
// limiting motor movements
motor.voltage_limit = 4.5; // [V]
motor.PID_velocity.P = 0.2;
motor.PID_velocity.I = 20;
motor.LPF_velocity.Tf = 0.01;
if(!motor.init()){
return;
