Hi! In need of urgent help ![]()
I’m making a device for ACL rehabilitation which attaches a gimbal motor to your knee to provide resistance and an accurate measure of range of motion.
Have successfully coded (in Arduino) the magnetic sensor, motor and the LCD together in one file, using a tft_espi widget. This enables the user to push against the motor resistance and test their range of motion.
I now want to provide multiple levels of resistance (and for each level of resistance to change the colour of the LCD dial). I coded a simple program which (when button is pressed) goes through three settings below:
// Variables will change:
int counter = 1;
int lastState = HIGH; // the previous state from the input pin
int nowState; // the current reading from the input pin
// initialize the pushbutton pin as an pull-up input
pinMode(BUTTON_PIN, INPUT_PULLUP);
// read the state of the switch/button:
nowState = digitalRead(BUTTON_PIN);
if(nowState != lastState){
delay(50);
if(nowState == LOW){
counter++;
if (counter>3){
counter=1;
Serial.println(counter);
// save the last state
lastState = nowState;
delay(10);
type or paste code here
When I try and incorporate this into the master code, I keep getting errors, even resorting to chat-gpt-4 which still can’t find a solution! I have successfully coded it so that the motor stops when the angle is 0 degrees (so that the user doesn’t break their knee!), but can’t seem to manage to have multiple settings via the press of a button.
This is the master code:
#define DRAW_DIGITS
#define BUTTON_PIN 21 // GIOP21 pin connected to button
//.frequency meter is updated
#define LOOP_DELAY 100
// Hardware-specific libraries
#include <SPI.h>
#include <TFT_eSPI.h>
BLDCDriver3PWM driver = BLDCDriver3PWM(27, 26, 25, 33);
#ifdef DRAW_DIGITS
#include "NotoSans_Bold.h"
#include "Futura.h"
#include "OpenFontRender.h"
#define TTF_FONTA NotoSans_Bold
#define TTF_FONTB Futura
#endif
TFT_eSPI tft = TFT_eSPI(); // Invoke custom library with default width and height
TFT_eSprite spr = TFT_eSprite(&tft); // Declare Sprite object "spr" with pointer to "tft" object
#ifdef DRAW_DIGITS
OpenFontRender ofr;
#endif
MagneticSensorSPI sensor = MagneticSensorSPI(5, 14, 0x3FFF);
#define BLACK 0x18E3
#define GREEN 0x75C8
#define YELLOW 0xF760
#define RED 0xEAC7
// Jpeg image array attached to this sketch
#include "dial.h"
#include <TJpg_Decoder.h>
// This function will be called during decoding of the jpeg file
bool tft_output(int16_t x, int16_t y, uint16_t w, uint16_t h, uint16_t* bitmap)
// Stop further decoding as image is running off bottom of screen
if ( y >= tft.height() ) return 0;
// This function will clip the image block rendering automatically at the TFT boundaries
tft.pushImage(x, y, w, h, bitmap);
// Return 1 to decode next block
return 1;
uint32_t runTime = 0; // time for next update
int reading = 0; // Value to be displayed
int d = 0; // Variable used for the sinewave test waveform
bool range_error = 0;
int8_t ramp = 1;
int counter = 1;
bool initMeter = true;
void setup(void) {
driver.voltage_limit = 12;
motor.voltage_limit = 12;
// choose FOC modulation
// set torque mode
// init motor hardware
// align sensor and start FOC
// The byte order can be swapped (set true for TFT_eSPI)
TJpgDec.setSwapBytes(true);
// The jpeg decoder must be given the exact name of the rendering function above
TJpgDec.setCallback(tft_output);
// draw screen
tft.fillScreen(TFT_NAVY);
// Draw the dial
TJpgDec.drawJpg(0, 0, dial, sizeof(dial));
tft.begin();
tft.setRotation(1);
tft.setViewport(0, 0, 240, 240);
float target_voltage = 7;
delay(50);
counter++;
if (counter>3){
counter=1;
delay(10);
static uint16_t maxRadius = 0;
int8_t ramp = 1;
static uint8_t radius = 0;
static int16_t xpos = tft.width() / 2;
static int16_t ypos = tft.height() / 2;
bool newMeter = false;
if (maxRadius == 0) {
maxRadius = tft.width();
if (tft.height() < maxRadius) maxRadius = tft.height();
maxRadius = maxRadius / 2;
radius = maxRadius*1.02;
tft.fillCircle(xpos, ypos, radius + 1, TFT_NAVY);
initMeter = true;
#ifdef DRAW_DIGITS
// Loading a font takes a few milliseconds, so for test purposes it is done outside the test loop
if (ofr.loadFont(TTF_FONTA, sizeof(TTF_FONTA))) {
Serial.println("Render initialize error");
return;
#endif
initMeter = true;
reading = 0;
ramp = 1;
while (!newMeter) {
if (millis() - runTime >= LOOP_DELAY) {
runTime = millis();
motor.move(target_voltage);
sensor.update();
int reading = (RAD_TO_DEG)*(sensor.getAngle());
if (reading<=0) {
reading = 0;
target_voltage = 0;
if (reading>=180) reading = 180;
if ((reading > 0) && (reading < 180)) target_voltage = 3;
ringMeter(xpos, ypos, radius, reading, "Degrees"); // Draw analogue meter
#ifdef DRAW_DIGITS
ofr.unloadFont(); // Recover space used by font metrics etc
#endif
// Draw the meter on the screen, returns x coord of righthand side
// x,y is centre of meter, r the radius, val a number in range 0-100, units is the meter scale label
void ringMeter(int x, int y, int r, int val, const char *units){
static uint16_t last_angle = 30;
if (initMeter) {
initMeter = false;
last_angle = 30;
tft.fillCircle(x, y, r, BLACK);
tft.drawSmoothCircle(x, y, r, TFT_SILVER, BLACK);
uint16_t tmp = r - 3;
tft.drawArc(x, y, tmp, tmp - tmp / 5, last_angle, 330, BLACK, BLACK);
r -= 3;
// Range here is 0-100 so value is scaled to an angle 30-330
int val_angle = map(val, 0, 180, 30, 330);
if (last_angle != val_angle) {
// Could load the required font here
//if (ofr.loadFont(TTF_FONT, sizeof(TTF_FONT))) {
// Serial.println("Render initialize error");
// return;
#ifdef DRAW_DIGITS
ofr.setDrawer(spr); // Link renderer to sprite (font will be rendered in sprite spr)
// Add value in centre if radius is a reasonable size
if ( r >= 25 ) {
// This code gets the font dimensions in pixels to determine the required the sprite size
ofr.setFontSize((6 * r) / 4); // was 4
ofr.setFontColor(TFT_WHITE, BLACK);
// The OpenFontRender library only has simple print functions...
// Digit jiggle for chaging values often happens with proportional fonts because
// digit glyph width varies ( 1 narrower that 4 for example). This code prints up to
// 3 digits with even spacing.
// A few experiemntal fudge factors are used here to position the
// digits in the sprite...
// Create a sprite to draw the digits into
uint8_t w = ofr.getTextWidth("444");
uint8_t h = ofr.getTextHeight("4") + 4; // was +4
spr.createSprite(w, h + 2);
spr.fillSprite(BLACK); // (TFT_BLUE); // (BLACK);
char str_buf[8]; // Buffed for string
itoa (val, str_buf, 10); // Convert value to string (null terminated)
uint8_t ptr = 0; // Pointer to a digit character
uint8_t dx = 4; // x offfset for cursor position
if (val < 100) dx = ofr.getTextWidth("4") / 2; // Adjust cursor x for 2 digits
if (val < 10) dx = ofr.getTextWidth("4"); // Adjust cursor x for 1 digit
while ((uint8_t)str_buf[ptr] != 0) ptr++; // Count the characters
while (ptr) {
ofr.setCursor(w - dx - w / 20, -h / 2.5); // Offset cursor position in sprtie
ofr.rprintf(str_buf + ptr - 1); // Draw a character
str_buf[ptr - 1] = 0; // Replace character with a null
dx += 1 + w / 3; // Adjust cursor for next character
ptr--; // Decrement character pointer
spr.pushSprite(x - w / 2, y - h / 2); // Push sprite containing the val number
spr.deleteSprite(); // Recover used memory
// Make the TFT the print destination, print the units label direct to the TFT
ofr.setDrawer(tft);
ofr.setFontSize(r / 4.0);
ofr.setCursor(x, y + (r * 0.4));
ofr.cprintf("Degrees");
#endif
// Allocate a value to the arc thickness dependant of radius
uint8_t thickness = r / 5;
if ( r < 25 ) thickness = r / 3;
// Update the arc, only the zone between last_angle and new val_angle is updated
if (val_angle > last_angle) {
tft.drawArc(x, y, r, r - thickness, last_angle, val_angle, GREEN, BLACK); // drawing arc
else {
tft.drawArc(x, y, r, r - thickness, val_angle, last_angle, BLACK, BLACK);
last_angle = val_angle; // Store meter arc position for next redraw
Thanks in advance, I know their is a lot of code to sift through - but any help in the next 24 hours would be invaluable <3
Callum
