Torque using voltage - Failed to notice movement
Hello everyone,
I’m new to SimpleFOC and very excited about this project.
I’m working with an iPower GM2804 Motor with a AS5048A Sensor connected over SPI, a SimpleFOC shield V3.2 and an Arduino Uno.
I have gone through the steps outlined in the getting started guide and have gotten the sensor to send the correct angle values to the serial monitor as well as the motor to move smoothly in open loop control.
I am now stuck at the next step: Closed-loop control - torque using voltage. I have adapted the code in the Examples (motion_control/torque_control/magnetic_sensor/voltage_control) to my hardware. However, I get the following error message in the serial monitor:
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: Init FOC failed.
FOC init failed!
I have tried the troubleshooting steps outlined in the guide but have not gotten it to work.
The motor does move slightly when starting the serial motor (making some noise) but then doesn’t react to any commands through the serial monitors. You can find a video of this behaviour here.
This is my code:
 * you a way to control motor torque by setting the voltage to the motor instead hte current.
BLDCDriver3PWM driver = BLDCDriver3PWM(6, 10, 5, 8);
// voltage set point variable
float target_voltage = 2;
  // power supply voltage
  // aligning voltage
  // align sensor and start FOC
  // Arduino UNO loop  ~1kHz
  // Bluepill loop ~10kHz
  motor.move(target_voltage);
  //Serial.print(sensor.getAngle());
Any pointers would be greatly appreciated!
Thank you and greetings from Vienna,
Marian
7
Your alignment voltage is set to 1V which is a bit low for this motor. If you increase it to 3 or 5V, do you get any movement during the initialization then?
The error you’re getting „Failed to notice movement“ either means the motor is not moving during initialization, or the sensor is not working.
You’ve checked the sensor is working independently, so my next question is: does the motor move during the initialization phase? It should turn about a quarter turn first in one direction, and then the other.
The issue might be that you’re using the pin 10 twice. Once for the Bald motor phase B and once for the chip select of the sensor.
You can confirm this by using a different chip select pin for your spi sensor. :slight_smile:
Hi @marian , welcome to SimpleFOC!
The code looks ok, I wonder is your sensor working? Did you test it independently of the motor?
Hi @runger,
thank you for the reply!
Yes, I did test the sensor independently from the motor and do get the correct angle values out.
I used the following code to test it and the result can be seen here.
// MagneticSensorSPI(MagneticSensorSPIConfig_s config, int cs)
//  config  - SPI config
//  cs      - SPI chip select pin
// alternative constructor (chipselsect, bit_resolution, angle_read_register, )
// MagneticSensorSPI sensor = MagneticSensorSPI(10, 14, 0x3FFF);
  // monitoring port
  // this function reads the sensor hardware and
  // has to be called before getAngle nad getVelocity
  sensor.update();
  float pi = 3.1415926535897932384626433832795;
  float deg = sensor.getAngle() *  180 / pi;
  //Serial.print(deg);
  Serial.print("\t");
I tried increasing the alignment voltage - the motor does move a little more during the initialization with higher voltage numbers but the error messages still remain the same.
Yes, the motor moves during the initialization phase but only slightly and it also makes some noises when moving - as can be seen in this clip.
I did some troubleshooting and managed to get it working with a SimpleFOC Mini and an Arduino Mega with the same code, only adjusting for the different hardware (pin numbers).
I would still be curious to know why it doesn’t work with the Uno and the Shield.
Thank you very much Antun, that did the trick :slight_smile:
Also thank you to Richard for the help.
