Hi,@Antun_Skuric.
Nice to see you again ,And thank guys for your reply
I’m sorry I didn’t post these days. ![]()
And I’m busy with my work recently. I’ll record a detailed video in a few days to describe the problem. ![]()
Hi,guys.
I recorded the serial monitor and the motor together today,If there are any problems, I will continue to improve, thanks everyone.
This is my code.
#include "SimpleFOC.h"
#define EN_GATE 8
#define M_PWM A1
#define M_OC A2
#define OC_ADJ A3
// The cs is Pin7,board is simplebgc mos v1.3
MagneticSensorSPI sensor = MagneticSensorSPI(7, 14, 0x3FFF);
// magnetic sensor instance
// MagneticSensorSPI sensor = MagneticSensorSPI(10, 14, 0x3FFF);
//MagneticSensorI2C sensor = MagneticSensorI2C(0x36, 12, 0x0E, 4);
// Motor instance
// BLDCMotor motor = BLDCMotor(9, 5, 6, 7, 8);
// Motor instace(Simplebgc v1.3) (MOT1 9,10,11;MOT2 3,5,6)
BLDCMotor motor = BLDCMotor(3, 5, 6, 14, 8);
// DRV8302 specific code
// M_OC - enable overcurrent protection
pinMode(M_OC,OUTPUT);
digitalWrite(M_OC,LOW);
// M_PWM - enable 3pwm mode
pinMode(M_PWM,OUTPUT);
digitalWrite(M_PWM,HIGH);
// OD_ADJ - set the maximum overcurrent limit possible
pinMode(OC_ADJ,OUTPUT);
digitalWrite(OC_ADJ,HIGH);
//12V
motor.voltage_power_supply = 12;
motor.controller = ControlType::velocity;
motor.PI_velocity.P = 0.001;
motor.PI_velocity.I = 0.2;
motor.PI_velocity.voltage_limit = 3;
motor.PI_velocity.voltage_ramp = 1000;
motor.LPF_velocity.Tf = 0.01;
motor.voltage_sensor_align = 0.1;
// align sensor and start FOC
Serial.println("Set the target velocity using serial terminal:");
float target_velocity = 0;
static String received_chars;
while (Serial.available()) {
// get the new byte:
received_chars += inChar;
// end of user input
if (inChar == '\n') {
// change the motor target
target_velocity = received_chars.toFloat();
Serial.print("Target velocity: ");
// reset the command buffer
received_chars = "";
//unsigned int timecnt;
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
//timecnt = millis()-timecnt;//Read once before testing the function,The unit is us
// motor.monitor();
serialReceiveUserCommand();
// timecnt = millis()-timecnt;//Subtract the last result after the function test is completed
// Serial.print("timecnt=");//print the "timecnt"
// Serial.println(timecnt );
Your P is quite low. Are you tuning at low speed? I find it hard to tune P at low speed, instead i tune at half max speed (say 20 radians/s) and tune P first (holding i to zero). If P can give you 70% of target speed (i.e 14 rad/s) without oscillation, then later add I.
What was the clock speed of your mcu?
