Hello team,
Can i drive the teknic m-2310p-ln-04k bldc motor by using simplefocShield + arduino uno?
phase to phase resistance:0.72 ohms
It has an encoder (4000 quadrature counts per revolution) also a hall sensor. I couldn’t drive it via sensors. Only can drive open loop. The sensors can not be compatible with simplefocshield? Actually i dont have too much experience with arduino. Please help me ![]()
- Torque control example using voltage control loop.
- Most of the low-end BLDC driver boards doesn’t have current measurement therefore SimpleFOC offers
- you a way to control motor torque by setting the voltage to the motor instead hte current.
- This makes the BLDC motor effectively a DC motor, and you can use it in a same way.
// encoder instance
Encoder encoder = Encoder(2, 3, 1000);
// channel A and B callbacks
// voltage set point variable
float target_voltage = 2;
encoder.init();
motor.linkSensor(&encoder);
// link driver
// aligning voltage
// align sensor and start FOC
command.add(‘T’, doTarget, “target voltage”);
Serial.println(F(“Set the target voltage using serial terminal:”));
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
motor.move(target_voltage);
MOT: Monitor enabled!
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: Init FOC failed.
Motor ready.
