Teensy 4.0 and SIMPLEFOC_TEENSY4_FORCE_CENTER_ALIGNED_3PWM
My first post…
I’m working with the SimpleFOC closed loop angle example and it’s working fine.
However, I’m obviously not using the build flags correctly, as with or without them I still get the message: “TEENSY-DRV: Configuring 3PWM with fast pwm. Please consider using center aligned pwm for better performance!”
Could you please help me with enabling those flags in the Arduino IDE environment. - Thanks!!
  • Arduino IDE v2.3.3
  • SimpleFOC 2.3.5 installed
  • Teensy 4.0
  • SimpleFOC Mini v1
  • AMT-103 Encoder
  • iPower GM4108H Gimbal Motor
Start of program…
#define SIMPLEFOC_TEENSY4_FORCE_CENTER_ALIGNED_3PWM
#define SIMPLEFOC_TEENSY_DEBUG
BLDCDriver3PWM driver = BLDCDriver3PWM( 8, 36, 37, 4 );
// encoder instance
Encoder encoder = Encoder( 14, 15, 500 );
Serial output…
MOT: Monitor enabled!
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: sensor_direction==CCW
MOT: PP check: OK!
MOT: Zero elec. angle: 4.49
MOT: No current sense.
MOT: Ready.
Motor ready.
