Hi, When I first setup my system, I used pins 3,4,5 on the Teensy. They are on (what I now know) different timers. FlexPWM(4.2, 2.0, 2.1). This caused the PWMs to not be aligned, and I think I burnt out my simpleFOC shield chip because of it. Is it documented anywhere that the 3 pins need to be on the same timer? When I put it on pins 4,5,6 (FlexPWM 2.0, 2.1, 2.2), they are now left aligned. 6PWM does a bunch of checking to make sure that pins are on the same timer. Should 3PWM also do that check?
(I have another post trying to figure out how to center align these PWM signals.)
Thanks!!!
Sam
