Hello, I need help with power supply and my STSPIN32G4.
When I’m using 24V and the built-in converter, I can’t upload any sketches (although there is 3.3V on the output). I was using an ST-Link V2 from a Nucleo board, and after connecting 3.3V from it, I was able to program my STM. Now, I’m using an ST-Link V3, which has no Vcc pin, and I can’t use it properly. When I disconnect the 24V and connect 3.3V directly, it works. I measured the 3.3V with an oscilloscope and didn’t find anything unusual. Where should I look for the problem?
I am able connect to MCU with STM32CubeProgrammer if it help with trobleshooting
Make sure you have the reset mode in STM32CubeProgrammer set to software reset. Hardware reset would likely disable the buck converter, cutting the 3V power just before doing the upload.
Yeah, but the 5.5V is only if the gate drive voltage VCC is generated externally. If you’re using the built-in buck converter you need a higher VM voltage, since its a buck and not a buck-boost converter…
