Hello!
I’ve been working with STSPIN32G4 for while with low voltage (9V), it works good
I set 24V and have problems with nFaults, it being set, meaning that driver is turned off, although no fault is indicated, status register: 10001000
I set driver.voltage_limit = 0.5, which i guess is not even enought to move my motor with velocity open loop, it’s just wobbling, when i move it by hand, fault occurs(driver stops), when i set it to higher value faults occurs right after turning on power supply
what can be wrong?
