STM32G030 build failure in stm32_adc_utils.cpp (#539)
Hi, I’d like to work on #539.
I checked the current dev branch at commit ae7b3add. stm32_adc_utils.cpp still calls LL_ADC_INJ_IsTriggerSourceSWStart() unconditionally, and ADC_ChannelConfTypeDef::Offset is still assigned on non-F1 targets. This matches the compiler errors reported for STM32G030.
The issue has no linked PR. I also checked the open PRs and found none addressing this G0 build failure. PR #554 touches the same file but changes different code.
Before I start, would you prefer a small compatibility patch that:
1)guards APIs and fields unavailable on STM32G0
2)adds STM32G030 to CI to catch the regression
I can set up the Arduino toolchain, reproduce the build failure, and target the dev branch once the direction is confirmed.
1 Answer
1
Hi there!
Thanks for the initiative.
The ideal would be to make it in a way to change the minimum and add the g0 to the GitHub CI workflows so that we test it automatically.
