STM32 Blue Pill doesn’t communicate with SimpleFOC
I just got a stm32 blue pill to try it out with SimpleFOC, but it doesn’t seem to work.
I tested it communicating with AS5600 through I2C by running the sensor test code. I loaded it using a Serial (or TTL?) to USB method.
The serial monitor doesn’t show anything, just blank.
Is there a way to get it working?
Hi @alexiswoo456,
Can you get serial output for other example sketches? Just a simple “Hello World”, does it print to the serial port?
For simpleFOC sketches, i can’t get any readings on the serial monitor.
For other sketches other than simpleFOC, then yes. Serial monitor do output readings.
Hi!
What’s the difference in the way the serial port is initialised?
Could you post your code?
This is a simple LED blink test with addition of printing onto the serial monitor to test my stm32 blue pill. This works without any issue.
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  Serial.println("High");
  delay(1000);                       // wait for a second
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
  Serial.println("Low");
Then I moved on to the SimpleFOC sensor test to test the AS5600 using stm32 blue pill. In this code, serial monitor doesn’t print anything, its just blank even though it has uploaded the code without any issue.
// MagneticSensorI2C(uint8_t _chip_address, float _cpr, uint8_t _angle_register_msb)
//  chip_address  I2C chip address
//  bit_resolution  resolution of the sensor
//  angle_register_msb  angle read register msb
//  bits_used_msb  number of used bits in msb register
// make sure to read the chip address and the chip angle register msb value from the datasheet
// also in most cases you will need external pull-ups on SDA and SCL lines!!!!!
// For AS5058B
// MagneticSensorI2C sensor = MagneticSensorI2C(0x40, 14, 0xFE, 8);
// Example of AS5600 configuration
  // monitoring port
  // configure i2C
  Wire.setClock(400000);
  // this function reads the sensor hardware and
  // has to be called before getAngle nad getVelocity
  sensor.update();
  Serial.print("\t");
Then I went on to test the AS5600 with the stm32 blue pill using Curious Scientist’s code (I removed/commented the OLED codes since I do not need them). This code ran without any issue and serial monitor outputs the value. (Link to Curious Scientist’s AS5600: AS5600 magnetic position encoder — Curious Scientist)
#include <Wire.h> //This is for i2C
//#include <SSD1306Ascii.h> //i2C OLED
//#include <SSD1306AsciiWire.h> //i2C OLED
// i2C OLED
#define I2C_ADDRESS 0x3C
#define RST_PIN -1
SSD1306AsciiWire oled;
float OLEDTimer = 0; //Timer for the screen refresh
//I2C pins:
//STM32: SDA: PB7 SCL: PB6
//Arduino: SDA: A4 SCL: A5
//Magnetic sensor things
int magnetStatus = 0; //value of the status register (MD, ML, MH)
int lowbyte; //raw angle 7:0
word highbyte; //raw angle 7:0 and 11:8
int rawAngle; //final raw angle
float degAngle; //raw angle in degrees (360/4096 * [value between 0-4095])
int quadrantNumber, previousquadrantNumber; //quadrant IDs
float numberofTurns = 0; //number of turns
float correctedAngle = 0; //tared angle - based on the startup value
float startAngle = 0; //starting angle
float totalAngle = 0; //total absolute angular displacement
float previoustotalAngle = 0; //for the display printing
void setup()
  Serial.begin(115200); //start serial - tip: don't use serial if you don't need it (speed considerations)
  Wire.begin(); //start i2C
  Wire.setClock(800000L); //fast clock
  checkMagnetPresence(); //check the magnet (blocks until magnet is found)
  ReadRawAngle(); //make a reading so the degAngle gets updated
  startAngle = degAngle; //update startAngle with degAngle - for taring
  //OLED part
  #if RST_PIN >= 0
    oled.begin(&Adafruit128x32, I2C_ADDRESS, RST_PIN);
  #else // RST_PIN >= 0
    oled.begin(&Adafruit128x32, I2C_ADDRESS);
  #endif // RST_PIN >= 0
  oled.setFont(Adafruit5x7);
  oled.clear(); //clear display
  oled.set2X(); //double-line font size - better to read it
  oled.println("Welcome!"); //print a welcome message
  oled.println("AS5600"); //print a welcome message
  delay(3000);
  OLEDTimer = millis(); //start the timer
void loop()
    ReadRawAngle(); //ask the value from the sensor
    correctAngle(); //tare the value
    checkQuadrant(); //check quadrant, check rotations, check absolute angular position
    //refreshDisplay();
    delay(100); //wait a little - adjust it for "better resolution"
void ReadRawAngle()
  //7:0 - bits
  Wire.beginTransmission(0x36); //connect to the sensor
  Wire.write(0x0D); //figure 21 - register map: Raw angle (7:0)
  Wire.endTransmission(); //end transmission
  Wire.requestFrom(0x36, 1); //request from the sensor
  while(Wire.available() == 0); //wait until it becomes available
  lowbyte = Wire.read(); //Reading the data after the request
  //11:8 - 4 bits
  Wire.write(0x0C); //figure 21 - register map: Raw angle (11:8)
  highbyte = Wire.read();
  //4 bits have to be shifted to its proper place as we want to build a 12-bit number
  highbyte = highbyte << 8; //shifting to left
  //What is happening here is the following: The variable is being shifted by 8 bits to the left:
  //Initial value: 00000000|00001111 (word = 16 bits or 2 bytes)
  //Left shifting by eight bits: 00001111|00000000 so, the high byte is filled in
  //Finally, we combine (bitwise OR) the two numbers:
  //High: 00001111|00000000
  //Low:  00000000|00001111
  //H|L:  00001111|00001111
  rawAngle = highbyte | lowbyte; //int is 16 bits (as well as the word)
  //We need to calculate the angle:
  //12 bit -> 4096 different levels: 360° is divided into 4096 equal parts:
  //360/4096 = 0.087890625
  //Multiply the output of the encoder with 0.087890625
  degAngle = rawAngle * 0.087890625;
  //Serial.print("Deg angle: ");
  //Serial.println(degAngle, 2); //absolute position of the encoder within the 0-360 circle
void correctAngle()
  //recalculate angle
  correctedAngle = degAngle - startAngle; //this tares the position
  if(correctedAngle < 0) //if the calculated angle is negative, we need to "normalize" it
  correctedAngle = correctedAngle + 360; //correction for negative numbers (i.e. -15 becomes +345)
  else
    //do nothing
  //Serial.print("Corrected angle: ");
  //Serial.println(correctedAngle, 2); //print the corrected/tared angle
void checkQuadrant()
  //Quadrants:
  4  |  1
  3  |  2
  //Quadrant 1
  if(correctedAngle >= 0 && correctedAngle <=90)
    quadrantNumber = 1;
  //Quadrant 2
  if(correctedAngle > 90 && correctedAngle <=180)
    quadrantNumber = 2;
  //Quadrant 3
  if(correctedAngle > 180 && correctedAngle <=270)
    quadrantNumber = 3;
  //Quadrant 4
  if(correctedAngle > 270 && correctedAngle <360)
    quadrantNumber = 4;
  //Serial.print("Quadrant: ");
  //Serial.println(quadrantNumber); //print our position "quadrant-wise"
  if(quadrantNumber != previousquadrantNumber) //if we changed quadrant
    if(quadrantNumber == 1 && previousquadrantNumber == 4)
      numberofTurns++; // 4 --> 1 transition: CW rotation
    if(quadrantNumber == 4 && previousquadrantNumber == 1)
      numberofTurns--; // 1 --> 4 transition: CCW rotation
    //this could be done between every quadrants so one can count every 1/4th of transition
    previousquadrantNumber = quadrantNumber;  //update to the current quadrant
  //Serial.print("Turns: ");
  //Serial.println(numberofTurns,0); //number of turns in absolute terms (can be negative which indicates CCW turns)
  //after we have the corrected angle and the turns, we can calculate the total absolute position
  totalAngle = (numberofTurns*360) + correctedAngle; //number of turns (+/-) plus the actual angle within the 0-360 range
  Serial.print("Total angle: ");
  Serial.println(totalAngle, 2); //absolute position of the motor expressed in degree angles, 2 digits
void checkMagnetPresence()
  //This function runs in the setup() and it locks the MCU until the magnet is not positioned properly
  while((magnetStatus & 32) != 32) //while the magnet is not adjusted to the proper distance - 32: MD = 1
    magnetStatus = 0; //reset reading
    Wire.write(0x0B); //figure 21 - register map: Status: MD ML MH
    magnetStatus = Wire.read(); //Reading the data after the request
    //Serial.print("Magnet status: ");
    //Serial.println(magnetStatus, BIN); //print it in binary so you can compare it to the table (fig 21)
  //Status register output: 0 0 MD ML MH 0 0 0
  //MH: Too strong magnet - 100111 - DEC: 39
  //ML: Too weak magnet - 10111 - DEC: 23
  //MD: OK magnet - 110111 - DEC: 55
  //Serial.println("Magnet found!");
  //delay(1000);
void refreshDisplay()
  if (millis() - OLEDTimer > 100) //chech if we will update at every 100 ms
    if(totalAngle != previoustotalAngle) //if there's a change in the position*
        oled.clear(); //delete the content of the display
        oled.println(totalAngle); //print the new absolute position
        OLEDTimer = millis(); //reset timer
        previoustotalAngle = totalAngle; //update the previous value
  else
    //skip
  //*idea: you can define a certain tolerance for the angle so the screen will not flicker
  //when there is a 0.08 change in the angle (sometimes the sensor reads uncertain values)
Hey,
What happens if you move the Wire.setClock() to be after the sensor.init() call?
I think that you’re not seeing any output because the program is crashing…
Moving the Wire.setClock() to be after the sensor.init() didnt solve the issue.
The arduino ide also did lag and sometimes hang for a short while when uploading the code.
I did try to use the pltformio for it but seems like it must be connected either using the STlink or flashed with bootloader. I do not have the stlink so I tried with the bootloader method and somehow mine failed to be flashed.
Maybe i could try to get a stlink and connect to the platform io and see whether it works or not.
Did you get the serial output with open loop example?
I use stlink and platformio with bluepill and it works perfectly. It might be due to your bootloader - I remember seeing somewhere that different bootloaders on STM32 have slight differences in serial comm.
