Stepper Motor not moving to target position
SETUP: I am using a Raspberry Pi Pico configured for the Arduino IDE using the Arduino-Pico library. I am using NEMA08-AMT112S series stepper motor that comes with an encoder. The driver is a standard L298N stepper driver board.
ISSUE: I am having issues moving to the motor target position. I have the motor target hard coded to a value of 3. However, when I run the following code, the motor moves for the initialization then holds itself at the zero position. The motor gets hot. I have it printing the motor angle and it says it is at 0. Without the motor driver being powered, the motor angle updates as I turn the motor shaft with my hands. What could be the cause of the issues?
#include <stdio.h>
#include "pico/stdlib.h"
#include "hardware/gpio.h"
#include "hardware/adc.h"
#define P1_PLUS 18
#define P1_MINUS 19
#define P2_PLUS 20
#define P2_MINUS 21
#define EN1 26
#define EN2 27
#define A 14
#define B 15
// Stepper driver instance
StepperMotor motor = StepperMotor(50 , 5.4);
StepperDriver4PWM driver = StepperDriver4PWM(P1_PLUS, P1_MINUS, P2_PLUS, P2_MINUS, EN1, EN2);
// encoder instance
Encoder encoder = Encoder(A, B, 2048);
// channel A and B callbacks
// commander interface
  gpio_init(P1_PLUS);        // Initialize GPIO
  gpio_set_dir(P1_PLUS, GPIO_OUT); // Set as output
  gpio_init(P1_MINUS);        // Initialize GPIO
  gpio_set_dir(P1_MINUS, GPIO_OUT); // Set as output
  gpio_init(P2_PLUS);        // Initialize GPIO
  gpio_set_dir(P2_PLUS, GPIO_OUT); // Set as output
  gpio_init(P2_MINUS);        // Initialize GPIO
  gpio_set_dir(P2_MINUS, GPIO_OUT); // Set as output
  gpio_init(EN1);        // Initialize GPIO
  gpio_set_dir(EN1, GPIO_OUT); // Set as output
  gpio_init(EN2);        // Initialize GPIO
  gpio_set_dir(EN2, GPIO_OUT); // Set as output
  gpio_init(A);        // Initialize GPIO
  gpio_set_dir(A, GPIO_IN); // Set as output
  gpio_init(B);        // Initialize GPIO
  gpio_set_dir(B, GPIO_IN); // Set as output
  encoder.init();
  motor.linkSensor(&encoder);
  // choose FOC modulation
  driver.enable();
  // link the motor to the driver
  driver.voltage_limit = 24;
  //motor.controller = MotionControlType::velocity_openloop;
  motor.PID_velocity.P = 0.1;
  motor.PID_velocity.I = 10;
  motor.PID_velocity.D = 0.00;
  motor.PID_velocity.output_ramp = 5;
  motor.LPF_velocity.Tf = 0.1;
  motor.current_limit = 1.6; // Amps -  default 2 Amps
  // angle loop controller
  motor.P_angle.P = 2;
  motor.P_angle.I = 0.5;
  motor.P_angle.D = 0;
  // angle loop velocity limit
  motor.velocity_limit = 5;
  Serial.begin(9600);
  //driver.enable();
  // initialise motor
  // define the motor id
  motor.target = 0;
  delay(1000);
  motor.target = 3;
Some things come to mind, mainly connection issues. 1. Most of the prefab'd L298N Boards do not support 24V. 2. Do you have the GND of the L298N, the Raspy and the Motor connected? 3. Do your Enable Pins have the correct polarity? You said, the motor gets hot, which phases are beeing powered with how much? Does the Sensor alignment work, what is the console output? BR Andy
2
@Andreas_Hofmann I should have clarified, the connections are all good. I know this because I am able to run the stepper motor and control the speed in open-loop mode. During the init stage, the motor turns back and forth and it looks like the only error is a PP check failure.
Could you give us the console log?
Have you tried running in closed loop torque or velocity mode? Angle mode depends on velocity, and velocity depends on torque, so it’s generally easiest to test them in order.
