Stepper motor haptic connection
I’m trying to use some adapted code to make a haptic connection between two nema 17 stepper motors using two as5600 sensors and l298n drivers. I am using the following code with an esp32 in the arduino ide. Unfortunately, I cant seem to get any response from the motors now matter how hard i try. Any advice would be greatly appreciated! Thanks.
Blockquote
//NOTES ABOUT ESP32
//GPIOs 34 to 39 can’t generate PWM
#include <Wire.h>
#define IN1_1 32
#define IN2_1 33
#define IN3_1 25
#define IN4_1 26
#define IN1_2 16
#define IN2_2 4
#define IN3_2 0
#define IN4_2 2
MagneticSensorI2C sensor0 = MagneticSensorI2C(AS5600_I2C);
MagneticSensorI2C sensor1 = MagneticSensorI2C(AS5600_I2C);
// motor instance
StepperMotor motor = StepperMotor(50); // StepperMotor(int pp, (optional R, KV))
StepperMotor motor2 = StepperMotor(50); // StepperMotor(int pp, (optional R, KV))
// driver instance
StepperDriver4PWM driver1 = StepperDriver4PWM(IN1_1, IN2_1, IN3_1, IN4_1); // StepperDriver4PWM(IN1, IN2, IN3, IN4, ENB, ENA)
StepperDriver4PWM driver2 = StepperDriver4PWM(IN1_2, IN2_2, IN3_2, IN4_2); // StepperDriver4PWM(IN1, IN2, IN3, IN4, ENB, ENA)
_delay(750);
Wire.setClock(400000);
Wire1.setClock(400000);
// Normally SimpleFOC will call begin for i2c but with esp32 begin() is the only way to set pins!
// It seems safe to call begin multiple times
Wire1.begin(16, 17, (uint32_t)400000);
sensor0.init();
sensor1.init(&Wire1);
// link motor to the sensor
motor.linkSensor(&sensor0);
motor2.linkSensor(&sensor1);
// choose FOC modulation
motor2.foc_modulation = FOCModulationType::SpaceVectorPWM;
driver1.voltage_power_supply = 12;
driver1.init();
driver2.voltage_power_supply = 12;
driver2.init();
motor.linkDriver(&driver1);
motor2.linkDriver(&driver2);
// motor limits
motor.current_limit = 1.0;
motor2.current_limit = 1.0;
// set control loop to be used
motor2.controller = MotionControlType::torque;
// initialise motor
motor2.init();
motor2.initFOC();
command.add(‘M’,onMotor,“my motor”);
motor.move(5*(motor2.shaft_angle - motor.shaft_angle));
motor2.loopFOC();
motor2.move(5*(motor.shaft_angle - motor2.shaft_angle));
Blockquote
I’m guessing your sensors are returning angles but the motors are not moving.
The l298n, I believe, requires 6pins to be connected but your code suggests you only have 4 pins connected or you’ve forgotten to specify ENA and ENB pins in StepperDriver4PWM constructor.
Maybe this old thread might help, their StepperDriver4PWM has 6 pins defined:
https://community.simplefoc.com/t/esp32-l298n-as5600-solved-wrong-pins/929
