Stacked Sheilds on STM32 G431 RB
Hi everybody, I am using two FOC Sheilds stacked on Nucleo 64 G431RB. Problem is both sheilds work individually with their respective motor, But when i stacked them, one of them stop working. Even when i enter angle for First motor it goes that position but somehow motor 1 also rotates a little bit.
// Motor 1 Big
// Motor 2 Small
BLDCMotor motor1 = BLDCMotor(2);
BLDCDriver3PWM driver1 = BLDCDriver3PWM(5, 10, 6, 8);
BLDCMotor motor2 = BLDCMotor(4);
BLDCDriver3PWM driver2  = BLDCDriver3PWM(3, 9, 13, 7);
//target variable
float target_position_1 = 0;
float target_position_2 = 0;
void doTarget1(char* cmd) { command.scalar(&target_position_1, cmd); }
void doLimit1(char* cmd) { command.scalar(&motor1.voltage_limit, cmd); }
void doVelocity1(char* cmd) { command.scalar(&motor1.velocity_limit, cmd); }
void doTarget2(char* cmd) { command.scalar(&target_position_2, cmd); }
void doLimit2(char* cmd) { command.scalar(&motor2.voltage_limit, cmd); }
void doVelocity2(char* cmd) { command.scalar(&motor2.velocity_limit, cmd); }
  driver1.voltage_power_supply = 12;
  driver2.voltage_power_supply = 12;
  driver1.voltage_limit = 6;
  driver2.voltage_limit = 6;
  if(!driver1.init()){
    Serial.println("Driver 1 init failed!");
    return;
    if(!driver2.init()){
    Serial.println("Driver 2 init failed!");
    return;
  motor1.linkDriver(&driver1);
  motor2.linkDriver(&driver2);
  // limiting motor movements
  // currnet = resistance*voltage, so try to be well under 1Amp
  motor1.voltage_limit = 1;   // [V]
  motor2.voltage_limit = 2;
  // limit/set the velocity of the transition in between
  // target angles
  motor1.velocity_limit = 30; // [rad/s] cca 50rpm
  motor2.velocity_limit = 30; // [rad/s] cca 50rpm
  // open loop control config
  motor1.controller = MotionControlType::angle_openloop;
  motor2.controller = MotionControlType::angle_openloop;
  // init motor hardware
  if(!motor1.init()){
    Serial.println("Motor 1 init failed!");
    return;
    if(!motor2.init()){
    Serial.println("Motor 2 init failed!");
    return;
  command.add('T', doTarget1, "target angle");
  command.add('L', doLimit1, "voltage limit");
  command.add('V', doLimit1, "movement velocity");
  command.add('t', doTarget2, "target angle");
  command.add('l', doLimit2, "voltage limit");
  command.add('v', doLimit2, "movement velocity");
  Serial.println("Motor 1 ready!");
  Serial.println("Set target position [rad]");
  Serial.println("Motor 2 ready!");
  motor1.move(target_position_1);
  motor2.move(target_position_2);
Here's an update. Both are working perfectly when i disconnected Hall Sensor from both Sheilds. On further observation it came to know that one of the shield hall sensor pin (#3) is soldered which is also been used in PWM pin for Second Sheild BLDCDriver3PWM(3, 9, 13, 7); . So after disconnecting it's working nicely.
