Some code question
hello.
i use shield v2.0.4 and AS5600 magnetic sensor, MKS 2808 bldc motor
i want to control motor velocity_control
so i use example code “velocity_control.ino”
but there was error that current sensor error
so i added code about current sensor, that is below.
but i’m not sure that’s right.
InlineCurrentSense current_sense = InlineCurrentSense(0.01f, 50.0f, A0, A2);
float target_velocity = 1.57;
current_sense.init();
current_sense.gain_b *=-1;
motor.PID_velocity.P = 0.2f;
motor.PID_velocity.I = 20;
motor.voltage_limit = 6;
Serial.println(F(“Set the target velocity using serial terminal:”));
1 Answer
1
Hi @ekftjgusrms , welcome to SimpleFOC!
Sorry that no one was able to help you with your problem so far.
Could you share the error message that you are getting?
May I suggest you try first without current sensing? Since you don’t set one of the current sensing modes in your code it is not being used anyway, and also it should not be needed for using this motor
