Hey Folks,
Complete newbie here with what seems like a very simple issue.
I am trying to control a GM3506 BLDC motor using an Nucleo Stm32F411RE and a SimpleFOC mini.
I have the driver in on pins 13,12,11,10, and powered with an external 12v power supply.
The Nucleo is powered via usb.
I’m trying to run the open loop position example through the Aurdino IDE.
It seems to flash without any issue however, I am not getting anything in the serial monitor, and never prints the motor ready prompt.
If send a value it does return in the serial monitor, but the motor does not move.
BLDCDriver3PWM driver = BLDCDriver3PWM(13, 12, 11, 10);
//target variable
float target_velocity = 0;
driver.voltage_limit = 6;
// limiting motor movements
// currnet = resistance*voltage, so try to be well under 1Amp
// open loop control config
// init motor hardware
I feel like there is something simple I am missing here and apologize in advance lol
