SimpleFOCMini + 50Ohm motor not turning
Hi All
I recently purchased a small motor from amazon that I wanted to use with SimpleFOCMini. However it’s actually advertised as more of a generator than a motor. Aliexpress store page. I mostly was hoping that I could use this as a motor since the form factor was small and the price was right(1$). I was not able to get it running with my SimpleFOCMini and adruino Mega. I’m sure that the driver and microcontroller are working properly as I have tested them both with a different motor. The motor stutters and vibrates at any speed at 12 volts when using open loop control. The only thing I can think to check is the phase to phase resistance. I measured 50Ohms phase to phase on the motor. I did have another driver that had better results driving the motor but I foolishly ruined it with overvoltage in the supply(DRV10964EVM -$100). Does anyone have experience with this exact motor? Or am I wasting my time trying to get this to run? Thanks in advance.
Can you share your code ?
@Candas1 @Valentine The code is pretty basic. Its the open loop example with a few extras to slowly ramp up the motor speed and then reverse direction.
BLDCDriver3PWM driver = BLDCDriver3PWM(11, 10, 9, 8);//Arduino pins Original
//BLDCDriver3PWM driver = BLDCDriver3PWM(25, 26, 27, 33);//ESP32 pins
//BLDCDriver3PWM driver = BLDCDriver3PWM(PA6, PA7, PB0, PA11);//STM32F030C8T6 pins
//target variable
float target_velocity = 0.0;
//variable to reverse direction
float reverse = 1.0;
//Start timer to follow millis()
unsigned long myTime;
//Create point to start a duration
unsigned long resetTime;
//Time since last reset point
unsigned long duration;
//const int MaxSpeed = 5;//Set max speed
const int MaxSpeed = 50;//Set max speed
//Create floating point time variable
float timer;
driver.pwm_frequency = 32000;
driver.voltage_power_supply = 8;
driver.voltage_limit = 8;
// limiting motor movements
motor.voltage_limit = 4; // [V]
// open loop control config
// init motor hardware
pinMode(LED_BUILTIN, OUTPUT);
myTime = millis();
// to turn the motor “backwards”, just set a negative target_velocity
myTime = millis();
duration = myTime - resetTime;//find duration of current sequence
timer = duration*1.0;//convert milliseconds to float
//target_velocity = MaxSpeed;
if(duration < 10000)
//Use floating point timer to increase target velocity
target_velocity = MaxSpeed*(timer/10000.0)*(reverse);
//target_velocity = (MaxSpeed*(timer/30000.0)*(reverse))+1;
if(duration>10000 && duration<60000)
target_velocity = MaxSpeed* (reverse);//Set maximum velocity
if(duration>60000 && duration<62000)
//digitalWrite(LED_BUILTIN, HIGH);
target_velocity = 0;//Stop and reverse motor
if(duration>62000)
//digitalWrite(LED_BUILTIN, LOW);
resetTime = millis();
reverse = reverse * (-1.0);
motor.move(target_velocity);//Set motor speed
@Valentine @Candas1 Here is a video link showing the behavior.
Stuttering motor video
Well it turns out that I had the driver wiring incorrect on this one. I had the enable pin and a motor input swapped and that is what caused the stuttering. Thankfully this only took a day to find. Otherwise the motor performs pretty good at low speeds less than 100 rpms. Not sure what the max is at 8 volts but probably a few hundred rpms.
