SimpleFOC studio not working
Hi guys,
I’ve been developing a code to control a BLDC motor with SimpleFOC on ESP32.
The problem is i can not get to work properly. If i send target values through serial the motor moves to the position without a problem but when I try to do it slowly it doesn’t go smooth at all. When using velocity open loop there’s no problem with the low speed movement, but in closed loop there is.
I’m using a AS5048_I2C and a Tmotor GB2208.
I’ve read that maybe my problem is the PID values but when I try to use SimpleFOCStudio in order to tune it, it only says “Unknown cmd err” even though I added commander to my standard code. My motor doesn’t move at all in this case.
Is there anybode else experiencing this? Does anyone know what’s going on?
The code:
#define SDA_PIN 25
#define SCL_PIN 26
#define I2C_FREQ 400000UL
float target_angle = 0;
MagneticSensorI2C sensor = MagneticSensorI2C(AS5048_I2C);
//InlineCurrentSense current_sense  = InlineCurrentSense(250, 34, _NC, 35);
BLDCDriver3PWM driver = BLDCDriver3PWM(19, 18, 5, 4);
void serialLoop() {
  static String recieved_chars;
  while (Serial.available()) {
    recieved_chars += inChar;
    if (inChar == '\n') {
      target_angle = recieved_chars.toFloat();
      Serial.print("target_angle = ");
      Serial.println(target_angle);
      recieved_chars = "";
  delay(1000);
  Wire.begin(SDA_PIN, SCL_PIN);
  Wire.setClock(I2C_FREQ);
 // current_sense.init();
  driver.voltage_power_supply = 7;
  driver.voltage_limit = 4;
 // current_sense.linkDriver(&driver);
  motor.voltage_limit = 4;
  motor.voltage_sensor_align = 47;
  //motor.linkCurrentSense(&crrent_sense);
  motor.PID_velocity.P = 0;
  motor.PID_velocity.I = 0;
  motor.PID_velocity.output_ramp = 50;
  //motor.LPF_velocity.Tf = 0.1f;
  motor.P_angle.P = 0;
  motor.P_angle.I = 0;
  motor.P_angle.D = 0;
  motor.velocity_limit = 500;
  command.add('M',doMotor,"motor");
  // tell the motor to use the monitoring
  motor.monitor_downsample = 0; // disable monitor at first - optional
  serialLoop();
  motor.move(target_angle);
1 Answer
1
Problem Analysis and Core Cause
Conflict Point: SimpleFOC Studio sends commands (e.g., M1.5\n or T10\n) through the serial port. It relies on command.run() to read and parse these commands.
Your Code: Your serialLoop() also runs at the beginning of the loop() function. It preemptively reads all incoming data from the serial port, including commands from SimpleFOC Studio.
Result: When command.run() executes, the serial buffer has already been emptied by your serialLoop(), so the Commander receives no commands, resulting in a lack of interactivity.
Solution: Remove Custom Parsing and Use Commander Directly
To solve this problem, we must remove the custom serialLoop() and let SimpleFOC Commander handle the target angle setting directly.
I have modified the code for you, and now you can use the built-in T (Target) command in SimpleFOC Studio to set the target angle.
Thanks for your reply, I really appreciate it. I still get the same error of "unknown cmd err" even with my serialLoop() deleted from the code. Any idea why could that be? Thanks in advance.
