SimpleFOC STM32 in ArduinoIDE
Hi, I am facing an issue of running SimpleFOC library in Arduino IDE for STM32 Nucleo 431RB. Code Below works on UNO. I have selected the Nucleo 431RB board in Boards manager, Code is not compiling. So just like Arduino i need to enter angle after code uplaoding via Serial Monitor. Thanks
#include <PciManager.h>
#include <PciListenerImp.h>
BLDCMotor motor = BLDCMotor(8);
BLDCDriver3PWM driver = BLDCDriver3PWM(PC7, PB4, PB10, 8);
// hall sensor instance
HallSensor sensor = HallSensor(PA10, PB3, PB5, 8);
// channel A and B callbacks
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
void doC(){sensor.handleC();}
PciListenerImp listenC(sensor.pinC, doC);
// angle set point variable
float target_angle = 0;
  // initialize sensor hardware
  sensor.enableInterrupts(doA, doB); //, doC);
  // software interrupts
  PciManager.registerListener(&listenC);
  // aligning voltage [V]
  // contoller configuration
  motor.PID_velocity.P = 0.1f;
  motor.PID_velocity.I = 0.2;
  motor.voltage_limit = 12;
  motor.LPF_velocity.Tf = 0.001f;
  // angle P controller
  motor.P_angle.P = 20;
  motor.velocity_limit = 4;
  // align sensor and start FOC
  motor.move(target_angle);
2
It’s easier to help you if you actually share the error messages.
But in this case I guess PciListenerImp is only available for arduinos.
You do not need the PCI manager for nicleo boards. This library works only for AVR boards.
Nucleo boards have enough interrupt pins and you can use them directly in enable interrupts. Uncomment le doC in the code. :slight_smile:
