Hi all, this is more of a FYI and an update to hopefully help someone else!
I’m running a STM32 NUCLEO-F411RE with an Aliexpress SimpleFOC Shield 2.0.4 working great in voltage mode but for the life of me couldn’t get the inline current sense working under FOC current mode! (All I got was erratic motor behavior, and or very loud PWM noise). It seemed so straight forward, and yet no luck. Even after reading all of the community posts on inverting phases, swapping A0 and A2 in the top setup line nothing seemed to work! If you are having trouble then I recommend putting in the (_NC) for phase C this seemed to do the trick for me and I just left the current sense alignment to do all the magic work it does, after this addition I couldn’t make it not work!
InlineCurrentSense current_sense = InlineCurrentSense(0.01, 50, A0, A2, _NC);
It would be great to see if someone else has discovered the same thing, then update the webpage to reflect this.
Thanks again!
