SimpleFOC control hub motor problem
Dear All,
Firstly, I used open-loop code to control the small BLDC motor. The result was quite well, the movement of the motor was smooth. Secondly, I used the same open-loop code but change the motor to a hub motor (bigger) instance of a small BLDC motor. I try to command the velocities are 1 and 7 rad/s, but the problems have occurred. For the first 10 seconds, the motor worked normally, after that the movement of the motor was jiggled with the current was decreased. Thirdly, I used closed-loop code to control the hub motor (big one). The result did not work, the motor did not completely move. Could you please guide me on how to make the hub motor move smoothly with open-loop or close-loop code?
Sincerely,
Prim.
This is the attached open-loop code;
//target variable
float target_velocity = 1;
  driver.voltage_limit = 6;
  // limiting motor movements
  // currnet = resistance*voltage, so try to be well under 1Amp
  // open loop control config
  // init motor hardware
@primpunn
Welcome to the forum, hope you find what you are looking for.
Could you please post more details about the hardware, board and motor, as well as preferably pictures/videos to understand the problem you are facing.
It is relatively difficult to provide feedback based on the short description you posted.
Also what sensors you are using for closed loop?
Please check this thread it may help.
https://community.simplefoc.com/t/gimbal-motor-overheating/1034/6
