Hi, I have troubles making simpleFOC mini board work. All connections are according to the examples I found on the internet, I power it directly from the power supply at 12V, however a red LED on the board constantly shines (I assume it indicates overcurrent). Problem disappears only when I reduce the voltage to ~0V, reducing the voltage limit in the software doesn’t help as well.
Obviously motor doesn’t move (sometimes it attempts to but fails). If it is helpful I am using arduino UNO R3, 5010 360kV BLDC motor, AS5600 magnetic sensor and as I said SimpleFOC mini v1.0 .
Thanks everyone in advance.
