Shunt current measurement considerations
First, I would like to introduce myself regarding this topic. I am a retired electrical engineer and specialist in EMC testing and design. In my work more years back I have designed smaller switch-mode power suplies and different high-power designs in 100 kW-range and 10 MVA range. I have not worked with ESC design, but I noticed more contributors here do it.
I have looked at some of the threads here and other places regarding using shunts to measure the current, and the problems included when you need to have a quite high measurement bandwidth. The self inductance of the shunt used is very important to consider in the design, and I have not noticed this issue to be addressed that much. When I look at the proposed PCB-designs from shunt manufacturers, then they only address the DC or low frequency aspects. This is why I am writing now. Please let me know, if you have seen this topic covered elsewhere.
I have seen previous threads here regarding this issue like here:
https://community.simplefoc.com/t/simplefoc-current-sensing-w-r-t-integrated-current-sensors-response-time/1018
But problems with current sense is discussed quite often.
I use some simple simulations of shunt behavior and signal filtering in LTSpice to make some analysis. Consider a design with shunts connected to ground from the source of the lower mosfet transistors on the half bridges. In this proposal I use pulse current of 20 A and of 5 us in length and with 50 ns rise and fall times. The shunt used is a 1 mohm SMD resistor, and for this calculation I estimate a self inductance of 2 nH:
The transient voltage on the shunt is about 0.8 V and value to be measured is 20 mV. So if you use this signal directly to a signal amplifier, it is likely to saturate, and you get some will have to wait for the amplifier to recover. Then it is normal to make some RC low pass filtering of the signal, and in this case you got a time constant of 0.5 us or bandwidth of about 300 kHz.
However, this is not an optimized design. You can optimize this by choosing an RC-filter with the same time constant as the time constant of the shunt (L/R). Then you actually get a perfect signal like this:
However, you need to be aware that you will have production inacuracies in actual self inductance and component values, and I do not expect that you can measure sensible before 2 us after a transition. But the aim here is to estimate the self inductance of the shunt and match the RC-filter afterwords.
This is how it looks like when you filter too much:
I this case you should wait about 5 us before you can measure reasonably.
Now, consider that you made the right RC compensation, but due to inaccuracies in shunt placement and PCB, the self inductance increased 10 % to 2.2 nH. Then you see this:
It will depend on how accurately you need to measure the current, how long you need to wait from after transition to when you sample the voltage in the ADC. I guess that with correct compensation you will need about 4 us for a resonable value.
Another approch is to work with the PCB design and how mutual inductances can be utilized to make a better and faster current signal.
I consider a 4-layer PCB-layout with these principles:
Layer 1: Upper PCB layer with connections to shunt and Power mosfet
Layer 2: Gound plane layer with only through-hole penetrations
Layer 3: Layer with connections to many smaller connections (red marked)
Layer 4: Layer with large power connections
Or this layout:
In these cases, the PCB design causes a mutual inductance to the signal, and it is the aim to eliminate the voltage caused by the self inductance of the shunt in the voltage signal from the shunt. For some SMD components it might be an issue to have through-hole plating below components so please consider a work around if this is the case.
These are the simulations of this case:
Here you see a situation, with slightly too little compensation. And the RC-filtering got a too high time constant for this.
This is a situation with the RC filter perfectly optimized for the same case:
In the case below, the mutual inductance overcompensates a little:
I think, that if you both make a PCB design utilizing mutual inductance, and you make a matching RC-filter, you will eliminate possible saturation of the signal amplifier, and be able to measures the current signal within 1 us from the transition.
I hope this might be usefull for some of you.
Welcome @Backflip!
This is very interesting topic, thanks for sharing!
I’ve got a few questions. :slight_smile:
  • Do you think that the same approach would make a difference regardless of the length of the leads between the shunt and the amplifier?
  • I’m also wondering what if we use the inline current sensing rather than low-side, where you’ve got one side of the shunt connected to the ground?
You would like to keep the RC-filter near the amplifier. I think you like to make a reference to the ground plane in the PCB. With a long line you may pick up signal due to some mutual inductance from high dI/dt paths elsewhere. If you use more ground-planes, you may be able to shield from that. But if the signal path is on some quiet part of the PCB, I do not see that much of a problem.
With inline current sensing you have got significantly lower dI/dt values in the shunt. Therefore it will be easier to handle. But the transient voltages on the shunt will still be significant, so matching with a RC-filter will be good practice. I have seen in-line solutions with some operational amplifiers with high common mode rejection capabilities. But I guess the limitation will be how good these common mode capabilities are at higher frequencies. It is much easier to specify good values for low frequencies.
I have seen hall-element current sensor components as well. I guess that you need to be aware of its sensitivity to other nearby high currents producing magnetic fields. But I have not any practical experience here.
I am not quite sure if this topic is placed in the right category at this forum. I guess it is about “hardware support”, but there it says: “This category is intended for any type of discussion about the hardware support of the SimpleFOClibrary”. I think this topic don’t comply to that, at the topic is more general than that, and it is also more general than one application.
But I got a question about the timing of the measurement of the current with one or more ADCs. I assume, that you can expect transients in the signals, when one of the half bridges are switching, so you like to avoid, that an ADC samples the signal close to any transition of the half bridges. I guess that the hardware near programming in some ways try to choose good timing to measure.
Am I right?
I think this will be that case both with in-line current measurements and with shunts to ground or other methods.
Hey @Backflip,
Yeah the categories are in a messy state at the moment. They were created at the beginning of the project when we did not expect the project to reach this awesome state. :smiley:
We’ve brainstormed on regrouping the topics in other ways but never got to the point of doing it at the end.
You’re absolutely right.
So at the moment we only explicitly use Timer+ADC synced for low-side current sensing. We are always trying to sample in the middle of the PWM cycle when all the low-side mosfets are active.
But as you suggested before, even for the in-line amps there is is a short transient due to the sudden change in the voltage. At this point we do not enforce the synchronisation between the Timers and ADCs when measuring the current in-line. Moslty because the transients are quite fast and in many cases much faster than the sample times of the ADC itself.
But what is definitely possible with SimpleFOC is to use the low-side current sensing logic with the inline current sensing. This will enforce ADC readings to be close to the center of the PWM cycle, and in most cases far away from the transients due to the PWM switching.
Thanks.
I made a couple of time line curves to show how I think it may be done. This may be documented in some diagrams elsewhere, and then I like to see it. The three wires to the motor are referenced R, S, and T. I guess that you aim to measure two or three currents while all the three halfbridges are switched low. I assume that a timer in the MCU is used counting up and down, and three compare registers are used to make signal to the halfbridges. The compare registers are given values that represent the wanted PWM voltage on each of the lines to the motor.
In a situation with about 50% voltage on motor and at an electrical angle, where the voltage on phase R is at max it should be like this:
This is another example with about 85% of max voltage, and when the voltage between R and T is at max:
You may think that you like to have three ADCs in the MCU to get all three currents. But in principle you may only measure the two currents with the lowest actual PWM voltage, because the last one will always be the negative sum of the two others. A popular MCU is STM32G431, and it only got two ADCs.
When you have about max voltage like seen in last figure, you start to get a problem, that one of the switching of one halfbridge gets close to the point the ADCs are triggered. So at near max voltage it will be close. I guess that in this situation you may like to switch to a different timing of the ADCs in some way. If you postpone the measurement a bit, you can measure the currents in the halfbridges with S and T without interference. But other ways may also handle this problem at max voltage.
