Seeking Help: Motor moving one full rotation during initFOC() and then stopping permanently
I have connected a Maxon EC45 50W Motor + Encoder with a TI DRV8313EVM to control the velocity of the motor. The motor is rotating one full rotation during the initFOC() phase but then stopping permanently and not accepting commands. I have separately run the encoder_test as well as the driver_test and they work as expected. Below is my code
BLDCMotor motor = BLDCMotor(8);
BLDCDriver3PWM driver = BLDCDriver3PWM(9, 5, 6, 8, 7, 10);
// encoder instance
Encoder encoder = Encoder(2, 3, 2048, A0);
// channel A and B callbacks
float target_velocity = 0;
void onTarget(char* cmd){ command.scalar(&target_velocity, cmd); }
  pinMode(11, OUTPUT); digitalWrite(11, HIGH);
  pinMode(12, OUTPUT); digitalWrite(12, HIGH);
  // initialize encoder hardware
  encoder.init();
  // hardware interrupt enable
  // power supply voltage
  // default 12V
  // link the motor to the driver
  // default P=0.5 I = 10
  motor.PID_velocity.P = 0.1;
  motor.PID_velocity.I = 1;
  //default voltage_power_supply
  motor.voltage_limit = 24;
  motor.voltage_sensor_align = 4;
  motor.LPF_velocity.Tf = 0.01;
  motor.linkSensor(&encoder);
  command.add('T', onTarget, "target velocity");
  // monitoring port
  Serial.println("Set the target velocity using serial terminal:");
  // iterative foc function
  // iterative function setting and calculating the velocity loop
  // this function can be run at much lower frequency than loopFOC function
1 Answer
1
Well, I don’t have an answer for you , but it seems to me that simplefoc should be returning error codes or throwing exceptions, but it does neither. So it really is a learning platform in the sense that you get to exercise your deductive powers to figure out the problems. But if you finally lose patience, you might consider modifying the library to log errors or something. I was almost about to do that but then I figured out my encoder was bad
