I am facing with a shaking issue. My code is pretty simple I will put it below. When I run my motor with an rotary encoder I drive it without any issue. However, since my project need magnetic encoder I should use as5600 or as5048A. With the same code, only encoder part is different, motor runs pretty bad and shaking like the video below. I changed PID, filter but I couldn’t solve the problem. if there was a problem with motor, it shouldn’t work with rotary encoder as well. So I coulnd’t find the problem. Any idea where is the problem?
Thanks for your help.
the video:
the graph:
BLDCMotor motor = BLDCMotor( 7 , 1.75 , 100);
BLDCDriver3PWM driver = BLDCDriver3PWM(33, 26, 14);
InlineCurrentSense current_sense = InlineCurrentSense(0.01, 5.18, 34, 35, 32);
MagneticSensorI2C magnetic = MagneticSensorI2C(0x36, 12, 0x0E, 4);
float target_velocity = 0;
void onMotor(char* cmd){ command.motor(&motor,cmd); }
void onTarget(char* cmd){ command.scalar(&target_velocity, cmd); }
// void onPID_P(char* cmd){ command.scalar(&motor.PID_velocity.P, cmd); }
// void onPID_I(char* cmd){ command.scalar(&motor.PID_velocity.I, cmd); }
// void onPID_D(char* cmd){ command.scalar(&motor.PID_velocity.D, cmd); }
// void onLPF(char* cmd){ command.scalar(&motor.LPF_velocity.Tf, cmd); }
magnetic.init();
motor.linkSensor(&magnetic);
driver.voltage_limit=12;
current_sense.init();
motor.PID_velocity.P = 0.2;
motor.PID_velocity.I = 20;
// motor.PID_velocity.output_ramp = 1000; lets use default this time
motor.LPF_velocity.Tf = 0.01;
motor.current_limit=2;
motor.velocity_limit=20;
motor.monitor_variables = _MON_VEL;
motor.monitor_downsample = 500;
command.add('T', onTarget, "target velocity");
command.add('M',onMotor,"my motor motion");
// command.add('P', onPID_P, "target P");
// command.add('I', onPID_I, "target I");
// command.add('D', onPID_D, "target D");
// command.add('F', onLPF, "target LPF");
