#include <BLDCMotor.h>
#include <float.h>
#include <SPI.h> /* include the SPI library necessary for the Orbis Absolute Position Encoder: */
const int slaveSelectPin = 10; //Pin 10 is the Slave Select for the Orbis Encoder
uint8_t OffsetHigh, OffsetLow; //Set Encoder Zero Offset variables
uint16_t EncoderZero; //Set Encoder Zero Offset 16 bit value
uint8_t Byte1, Byte2, Byte3, Byte4, Byte5, Byte6, EncoderGenStatus; //Orbis Encoder Data Transfer Variables
uint8_t crc_in;
uint8_t b_Index = 0;
uint8_t b_CRC = 0;
uint16_t EncoderPosition = 8191; // position in counts - 8191 is the encoder midway point
float encoder_angle = _PI; // encoder angle in radians defaults to encoder “zero” ie halfway point = PI
/* Absolute Encoder CRC Lookup Table /
/ Lookup table for polynome = 0x97 */
uint8_t tableCRC[256] = {
0x00, 0x97, 0xB9, 0x2E, 0xE5, 0x72, 0x5C, 0xCB, 0x5D, 0xCA, 0xE4, 0x73, 0xB8, 0x2F, 0x01, 0x96,
0xBA, 0x2D, 0x03, 0x94, 0x5F, 0xC8, 0xE6, 0x71, 0xE7, 0x70, 0x5E, 0xC9, 0x02, 0x95, 0xBB, 0x2C,
0xE3, 0x74, 0x5A, 0xCD, 0x06, 0x91, 0xBF, 0x28, 0xBE, 0x29, 0x07, 0x90, 0x5B, 0xCC, 0xE2, 0x75,
0x59, 0xCE, 0xE0, 0x77, 0xBC, 0x2B, 0x05, 0x92, 0x04, 0x93, 0xBD, 0x2A, 0xE1, 0x76, 0x58, 0xCF,
0x51, 0xC6, 0xE8, 0x7F, 0xB4, 0x23, 0x0D, 0x9A, 0x0C, 0x9B, 0xB5, 0x22, 0xE9, 0x7E, 0x50, 0xC7,
0xEB, 0x7C, 0x52, 0xC5, 0x0E, 0x99, 0xB7, 0x20, 0xB6, 0x21, 0x0F, 0x98, 0x53, 0xC4, 0xEA, 0x7D,
0xB2, 0x25, 0x0B, 0x9C, 0x57, 0xC0, 0xEE, 0x79, 0xEF, 0x78, 0x56, 0xC1, 0x0A, 0x9D, 0xB3, 0x24,
0x08, 0x9F, 0xB1, 0x26, 0xED, 0x7A, 0x54, 0xC3, 0x55, 0xC2, 0xEC, 0x7B, 0xB0, 0x27, 0x09, 0x9E,
0xA2, 0x35, 0x1B, 0x8C, 0x47, 0xD0, 0xFE, 0x69, 0xFF, 0x68, 0x46, 0xD1, 0x1A, 0x8D, 0xA3, 0x34,
0x18, 0x8F, 0xA1, 0x36, 0xFD, 0x6A, 0x44, 0xD3, 0x45, 0xD2, 0xFC, 0x6B, 0xA0, 0x37, 0x19, 0x8E,
0x41, 0xD6, 0xF8, 0x6F, 0xA4, 0x33, 0x1D, 0x8A, 0x1C, 0x8B, 0xA5, 0x32, 0xF9, 0x6E, 0x40, 0xD7,
0xFB, 0x6C, 0x42, 0xD5, 0x1E, 0x89, 0xA7, 0x30, 0xA6, 0x31, 0x1F, 0x88, 0x43, 0xD4, 0xFA, 0x6D,
0xF3, 0x64, 0x4A, 0xDD, 0x16, 0x81, 0xAF, 0x38, 0xAE, 0x39, 0x17, 0x80, 0x4B, 0xDC, 0xF2, 0x65,
0x49, 0xDE, 0xF0, 0x67, 0xAC, 0x3B, 0x15, 0x82, 0x14, 0x83, 0xAD, 0x3A, 0xF1, 0x66, 0x48, 0xDF,
0x10, 0x87, 0xA9, 0x3E, 0xF5, 0x62, 0x4C, 0xDB, 0x4D, 0xDA, 0xF4, 0x63, 0xA8, 0x3F, 0x11, 0x86,
0xAA, 0x3D, 0x13, 0x84, 0x4F, 0xD8, 0xF6, 0x61, 0xF7, 0x60, 0x4E, 0xD9, 0x12, 0x85, 0xAB, 0x3C
/ Read Orbis Encoder Position and Convert to Radians /
float readSensor() {
SPI.beginTransaction(SPISettings(2000000, MSBFIRST, SPI_MODE1));
digitalWrite (slaveSelectPin, LOW);
delayMicroseconds(3);
Byte1 = SPI.transfer(0x64);
Byte2 = SPI.transfer(0);
Byte3 = SPI.transfer(0);
Byte4 = SPI.transfer(0);
digitalWrite (slaveSelectPin, HIGH);
SPI.endTransaction();
b_Index = Byte1;
b_CRC = Byte2;
b_Index = b_CRC ^ tableCRC[b_Index];
b_CRC = Byte3;
b_CRC = tableCRC[b_Index];
if ((255 - Byte4) == b_CRC) {
EncoderPosition = ((((Byte1 << 8) | Byte2) & 0xFFFC) >> 2) + 0; //for the 14 bit encoder position from Byte1 and Byte2 data
EncoderGenStatus = Byte2 % 0b0000011;
return (float)(EncoderPosition * _2PI / 16383.0);
else {
/ Initialize the Orbis Encoder SPI Interface /
void initSensor() {
pinMode (slaveSelectPin, OUTPUT);
SPI.begin();
// generic sensor class contructor
GenericSensor Orbis = GenericSensor(readSensor, initSensor);
/ Setup and Initialization /
Orbis.init();
Orbis.update();
Orbis.getVelocity();
Orbis.getMechanicalAngle();
Orbis.getAngle();
motor.linkSensor(&Orbis);
Orbis.update();
Orbis.getAngle();
/ Main Program Loop /
/ Read the most recent EncoderPosition variable and convert to radians, external to SimpleFOC but SimpleFOC is updating the /
/ variable EncoderPosition when it calls the readsensor() function /
encoder_angle = (float)EncoderPosition * _2PI / 16383.0;
//*******************************CRC8 decode routines ******************************************
static uint8_t updateCrc8(uint8_t crc, uint8_t crc_seed) {
uint8_t crc_u = crc;
crc_u ^= crc_seed;
for (int i = 0; i < 8; i++) {
crc_u = ( crc_u & 0x80 ) ? 0x7 ^ ( crc_u << 1 ) : ( crc_u << 1 );
return (crc_u);
uint8_t calculateCrc8(const uint8_t *Buf, const uint8_t BufLen) {
uint8_t crc = 0;
for (int i = 0; i < BufLen; i++) {
crc = updateCrc8(Buf[i], crc);
return crc;
/ Set Encoder Zero Offset Value /
void SetEncoderZeroOffset(uint8_t OffsetHigh, uint8_t OffsetLow) {
// Detailed Status Data Command “Z”
delay(1);
SPI.transfer(0xCD); //Unlock Code
delay(1);
delay(1);
delay(1);
SPI.transfer(0xEF); //Unlock Code
delay(1);
delay(1);
delay(1);
SPI.transfer(0x89); //Unlock Code
delay(1);
delay(1);
delay(1);
SPI.transfer(0xAB); //Unlock Code
delay(1);
delay(1);
delay(1);
SPI.transfer(0x5A); // Z command
delay(1);
delay(1);
delay(1);
SPI.transfer(0x00); //Offset 0 Byte
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
SPI.transfer(OffsetHigh); //Offset High Byte
delay(1);
delay(1);
delay(1);
SPI.transfer(OffsetLow); //Offset Low Byte
delay(1);
delay(1);
/ Save Encoder Configuration to Non-Volatile Memory /
void SaveEncoderConfig() {
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
SPI.transfer(0x63); // c command
delay(1);
/ Reset Encoder Configuration Factory Default /
void EncoderConfigReset() {
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
SPI.transfer(0x72); // r command
delay(1);
/ Trigger Self-calibration Function /
void EncoderCalibration() {
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
SPI.transfer(0x41); // A command
delay(1);
