Hi everyone!
I am working on my speed and position project with SimpleFOC.
I’m using a SunnySky X2212 motor with a B_431_ESC1 and an AS5600 encoder. Everything is working well so far! However, I’m wondering which parameters I should adjust to make the controller drive the motor a bit harder — right now, it stalls quite easily and doesn’t spin at low speeds. The motor is currently drawing less than 250 mA.
Any tutorial or guidance is appreciated!
Code that I use for speed control:
#include <Wire.h>
BLDCMotor motor = BLDCMotor(7, 0.133, 980); // SunnySky x2122
BLDCDriver6PWM driver = BLDCDriver6PWM(A_PHASE_UH,
A_PHASE_UL,
A_PHASE_VH,
A_PHASE_VL,
A_PHASE_WH,
A_PHASE_WL);
MagneticSensorI2C as5600 = MagneticSensorI2C(AS5600_I2C);
// angle set point variable
float target_angle = 0;
// commander interface
void onTarget(char* cmd){ command.scalar(&target_angle, cmd); }
// the setup routine runs once when you press reset:
Serial.println("Initializing....");
// sensor
as5600.init();
motor.linkSensor(&as5600);
driver.voltage_power_supply = 12.0;
//driver.voltage_limit = 2.4; // limit the source voltage because it heats up
// Need to setup velocity!
// default P=0.5 I = 10 D =0
motor.PID_velocity.P = 1;
motor.PID_velocity.I = 10;
//motor.PID_velocity.D = 0.001;
// choose FOC modulation
// limiting motor movements
motor.voltage_limit = 1; // [V]// do not increase it more! 133mΩ so 1V / 0.133 = 7.5A. Also, half of 'driver.voltage_limit' NOTE THAT too big voltage limit when power supply is not good to deliver amps will make motor fail and make weird sounds!
// limit current
//motor.current_limit = 9.0; // amps
motor.P_angle.P = 25;
// motor.P_angle.I = 0.001;
// motor.LPF_angle.Tf = 0.01f;
// this variable is in rad/s^2 and sets the limit of acceleration
motor.P_angle.output_ramp = 1000000; // default 1e6 rad/s^2
// --- Filtering ---
motor.LPF_angle.Tf = 0.01; // reduce AS5600 noise
motor.LPF_velocity.Tf = 0.02; // smooth measured speed
// limit speed
motor.velocity_limit = 50; // [rad/s]
// open loop control config
Serial.println("Motor initialization started!");
// init motor hardware
Serial.println("Motor initialization! Aligning encoder!");
Serial.println("Motor initialization!");
command.add('T', onTarget, "target angle");
delay(1000);
// the loop routine runs over and over again forever:
motor.move(target_angle);
Issue video:
5
Probably just the low voltage and current limits (which is a wise choice for initial setup). Once you get the current sense set up, you can set voltage limit 6 with SinePWM or 7 with SpaceVectorPWM, and current limit 5 amps, or 10 if you have a fan blowing on the driver or can reasonably guarantee that it won’t need more than 5 amps for more than a few seconds at a time. The documentation claims 40 amp capability, but according to my personal testing using my finger as a temperature probe, it’s uncomfortably hot to touch after running at 6 amps until it reaches equilibrium temperature.
// limit current
motor.current_limit = 5.0; // amps
This config works well!
@dekutree64 Thank you for the previous suggestion!
I made changes in the code and also tested a bit higher voltage_limit (up to 3V with this motor, this motor have low resistance, only 0.133mΩ - don’t want to increase it too much).
My current code is here. It works well; however, in the position control, I am still able to stall the motor and it draws max 300-330mA (with increased voltage limit and also PID adjustments). My code is here:
#include <Wire.h>
A_PHASE_UL,
A_PHASE_VH,
A_PHASE_VL,
A_PHASE_WH,
A_PHASE_WL);
// sensor
as5600.init();
motor.PID_velocity.P = 0.2f;
motor.PID_velocity.I = 20;
motor.voltage_limit = 1.5; // [V]// do not increase it more! 133mΩ so 1V / 0.133 = 7.5A. Also, half of 'driver.voltage_limit' NOTE THAT too big voltage limit when power supply is not good to deliver amps will make motor fail and make weird sounds!
// limit current
motor.P_angle.I = 0.2;
motor.LPF_angle.Tf = 0.001; // reduce AS5600 noise
//motor.LPF_velocity.Tf = 0.01; // smooth measured speed
// limit speed
motor.velocity_limit = 75; // [rad/s]
delay(1000);
Also, attaching the video:
Is it possible to make the driver use more current and make harder to stop?
300mA from the supply when the motor is stalled is 3.6 watts of waste heat, implying about 5 amps motor current, so it looks like your parameters are tuned well. Using the torque equation current x 8.3 / kv, you should have about 44mNm. That’s about all your motor and ESC1 can use continuously without cooling, but you can go up to 10 amps for a few seconds at a time, or possibly continuously if you have a fan blowing on it. Otherwise you’ll need a larger, lower kv motor to get more torque from those 5-10 amps.
@dekutree64 Thank you for the help! Indeed, 10Amps might be an option. But for this project, even 5 might be good enough. Thank you again!
