Hey!
I’ve been trying to setup an AS5048a magnetic encoder with my Teensy 4.0. i’ve just been trying to run the unmodified magnetic_sensor_spi_example.ino script with the Arduino IDE. So far I’ve only been able to get a string of zeros (see below).
However, this works just fine with an arduino uno.
I’m confident that my wiring is correct (CS->10, MOSI->11, MISO->12, SCK->13). Has anyone else experienced this issue?
Lol my colorblindness has gotten me in trouble before, but I’m very confident in my pin setup.
Thanks for sharing that link! I got it working… sort of! The functions contained in AS5048A.cpp are working properly (see attached image), whereas the other functions (getAngle, getCurrentAngle) are not. Wish I could be more helpful with debugging but I am veryyy new to C++
Huh, that’s certainly an improvement… that means the sensor is working, the SPI is working, the driver for the sensor is working… it’s just the base class values that aren’t updating.
May I ask, to be sure, are you calling sensor.update() once each time through the loop, before calling getAngle() and getVelocity()?
If so, can I ask what happens if you add a delay to the loop (delay(500);) ?
[Edit]
Oh, I see it looks like you already have a delay in there
Ahh ok I don’t think I called sensor.update(), I just copy & pasted the example code from the link you shared. I’ll try that this evening & report back.
